air horns with alarm?
nokie1
Member - Posts: 20
Posted: February 23, 2009 at 6:32 PM / IP Logged
hello,
i just installed some air horns and i wanna know can my air horns sound with my alarm? if so how would i hook it up?
                                                              thanks
Platinum - Posts: 13,726
Posted: February 23, 2009 at 6:46 PM / IP Logged
Yes you can connect the air horns to the alarm.   Are you using the light flash wire from your alarm?  There is a relay on the air horns, there is a switch that triggers that relay, is the other side of the switch connected to power or to ground?
nokie1
Member - Posts: 20
Posted: February 23, 2009 at 8:14 PM / IP Logged
the switch is connected to power.
Posted: February 23, 2009 at 8:31 PM / IP Logged
There were 2 questions.
nokie1
Member - Posts: 20
Posted: February 23, 2009 at 11:05 PM / IP Logged
not using anything right now,i wanted to know how to do it.
Posted: February 24, 2009 at 2:50 AM / IP Logged
Let us know what alarm you're using, there might be a secondary horn output.
Posted: February 24, 2009 at 3:19 AM / IP Logged
Is that the answer to the Light Flash wire question?
Posted: February 24, 2009 at 5:16 AM / IP Logged
If you haven't an alarm why are you asking? Yes it can be done light flash as suggested or some units have a secondary neg going horn output which can be set via a relay to convert to pos and feed your air horn relay. This output can be programmed for constant or on/off output, so now pick an alarm.
nokie1
Member - Posts: 20
Posted: February 24, 2009 at 5:20 PM / IP Logged
i have a prestige aps-997a remote start alarm.
Posted: February 24, 2009 at 5:52 PM / IP Logged
When you remote start the vehicle, do the parking lights illuminate to let you know the vehicle is running?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
