aftermarket alarm with factory fob
Installtech323
Member - Posts: 18
Posted: February 23, 2009 at 10:25 PM / IP Logged
hello to everyone
is their any alarm out their that you could program to work with a factory key fob with and without remote start??
mecp certified tech
dr.jon007
Member - Posts: 9
Posted: February 23, 2009 at 10:34 PM / IP Logged
The last one I used was the Hornet (727t I think) It uses the lock system in the vehicle (activated by the factory keyless) to arm and disarm the aftermarket alarm.
Installtech323
Member - Posts: 18
Posted: February 23, 2009 at 10:39 PM / IP Logged
thanks for the info i will look in o it
mecp certified tech
mikvot
Gold - Posts: 1,043
Posted: February 24, 2009 at 11:31 PM / IP Logged
Code Alarm also makes the ca310, which will do what you want.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 25, 2009 at 11:10 AM / IP Logged
There's also the Audiovox PRO-9233, which is probably the same as that Code Alarm CA310.
If you find a PRO9232A or a PRO9232, those are just older versions of the 9233.
