parking brake wire on 06 08 civic
Thack79
Silver - Posts: 526
Posted: March 16, 2009 at 10:20 AM / IP Logged
Looking for the parking brake wire in the drivers kick. know its light green or orange somewhere there. can some one give me a better description.
in drivers harnesss to rears? one of the three plugs at the bottom? high in kick panel?  behind fuse box, etc?
ajstetler
Copper - Posts: 94
Posted: March 16, 2009 at 10:01 PM / IP Logged
I find it easiest to get it at the instrument cluster.
Big Al
tedmond
Gold - Posts: 4,610
Posted: March 16, 2009 at 11:47 PM / IP Logged
why do you need the parking brake wire? if its an auto just ground it. If its manual wire up the proper units such as 689m, or a VSS. are you sure its not the neutral safety your looking for ? that wire is negative GREEN @ gear selector. the best/more efficant way is go to the handbrake itself.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 17, 2009 at 1:08 AM / IP Logged
Ebrake is Lt.Blue behind the inst. cluster. OR it can be found as an orange in the bottom plug in the drivers kick.
Thack79
Silver - Posts: 526
Posted: March 17, 2009 at 8:03 AM / IP Logged
Orange is what im looking for. Thanks Kartune (and all feedback). Is the instrument cluster that easy to get to? I just know what it takes just to get to the radio I didnt think it would be.
yeah its neutral safety. and its manual. i saw somewhere it said that it was in the drivers kick and since everything is over there i dont wanna pull off the center console. Thanks all.
ajstetler
Copper - Posts: 94
Posted: March 17, 2009 at 9:31 AM / IP Logged
You can access the instrument cluster in the same process to remove the radio. Remove panel below steering column, remove one hidden screw behind removed panel, pop off panel around instrument cluster, remove four screws around instrument cluster and it pulls out.
Big Al
