2000 f 150 remote start, tach wire
jmholden46
Member - Posts: 12
Posted: May 24, 2009 at 12:04 PM / IP Logged
Hey Guys,
I am installing a Viper 160XV Remote Start system into my 2000 Ford F-150.   I dont have much knowledge about cars in general but I read a lot of posts here before I gave it a shot at installing it.   Anyway, I have read that the best tach wire is to use one of the wires from a fuel injector (any color but red).   Now the only question is how the heck do I get my wires from inside the cab through the fire block and into the engine compartment?
On a seperate note, Is the hood pin switch really required?   I can't just hook the wire from the unit directly to ground?  (i read a post where a guy had an issue with that).   in either case, the F-150 doesn't come stock with a hood senser correct?   So I'll have to install a hood pin swich to monitor the hood opening.
Thanks for all your help up to this point.   These Forums have been very helpful.
-BiG J-
jmholden46
Member - Posts: 12
Posted: May 24, 2009 at 12:32 PM / IP Logged
ok will I just read elsewhere that I wont need to go through the firewall to attach to the fuel injector wires.   On the Power train control module (PCM) I can use the WHITE/ Pink wire.   The PCM I also just found out lol is the Main computer located behind the driver kick panel (white square unit maybe 4 inches x 4 inches).   I was wondering what that thing was...
-BiG J-
chev104275
Gold - Posts: 1,436
Posted: May 24, 2009 at 4:14 PM / IP Logged
the pcm is in the engine compartment on the right side use an existing grommet in the fire wall to run the wires through i usually use the odd color wire from any injector for tach    i always use a hood pin    it keeps your mechanics hands intact
jmholden46
Member - Posts: 12
Posted: May 24, 2009 at 9:51 PM / IP Logged
Thanks,
Well, now I know why a hood pin is important.   I never saw it that way.
-BiG J-
chev104275
Gold - Posts: 1,436
Posted: May 26, 2009 at 6:23 AM / IP Logged
on my 2000 f150 with a 4.2L motor im using the blue/green wire at the main coi for tach working great for 4 years now   asianwolf 8000RS system
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
