how to make headlights come on w/ keyless
ubnpast
Member - Posts: 29
Posted: May 27, 2009 at 1:34 PM / IP Logged
I have a 2000 Mitsubishi Mirage.  I have an alarm which has a trunk popper which is currently not being used.  My question is What would I use to make my headlights stay on for about 2 minutes, for example its dark out so I push the button for the trunk popper and my headlights come on for 2 minutes then go off?  The trunk popper is only a pulse and not constant.
KPierson
Platinum - Posts: 3,527
Posted: May 27, 2009 at 1:44 PM / IP Logged
You can get a off delay timer relay.  Once the pulse comes and goes the relay stays energized for a preset amount of time.  I believe the PAC TR7 will do that.
Kevin Pierson
ubnpast
Member - Posts: 29
Posted: May 27, 2009 at 2:03 PM / IP Logged
I found that I could use the DEI 528t, http://akamaipix.crutchfield.com/Manuals/607/607528T.PDF
How would I connect the wires,
Red would be constant 12v+
Black would be Ground (-)
Black w/white stripe would be the wire from the alarm for the trunk popper
How about the yellow (common), orange (NC),  brown (NO)?
KPierson
Posted: May 27, 2009 at 2:17 PM / IP Logged
You would need to find out how to turn the lights on in your vehicle.
If it is a + switch then connect 12vdc to the common wire and the NO wire goes to the headlight switch wire
If it is a - switch then connected ground to the common wire and the NO wire goes to the headlight switch wire
Kevin Pierson
ckeeler
Gold - Posts: 1,461
Posted: May 27, 2009 at 2:19 PM / IP Logged
yellow will go to 12v. brown will go to the headlights. orange is not used. the 528t will only go for a max of 60 seconds though.
ubnpast
Member - Posts: 29
Posted: May 27, 2009 at 2:20 PM / IP Logged
According to this site it is: RED / White (-).  So I should ground the Common wire and the NO wire just taps into the RED / White (-) wire?< size=7 face=Futura-CondensedExtraBold>< size=7 face=Futura-CondensedExtraBold>
ubnpast
Member - Posts: 29
Posted: May 27, 2009 at 2:21 PM / IP Logged
Any recommendations for something that is inexpensive and lasts a little longer?
KPierson
Posted: May 27, 2009 at 4:16 PM / IP Logged
Cascade two TR7s together!    :)
Kevin Pierson
ubnpast
Member - Posts: 29
Posted: May 27, 2009 at 11:03 PM / IP Logged
I have read that the DEI unit is 90 seconds, even so 60 would most likley be enough.  I could try to push the button on the remote again maybe that would extend the ON time.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
