wiring diagram for an omega max e alarm
steveosgrl7
Posted: May 29, 2009 at 5:24 PM / IP Logged
I have an 05 Cavalier. I need to know how to install my Omega Max E alarm. It has remote start. I bought the alarm without a manual. Any input would be appreciated. I am at a loss. Thanks
tommy...
Gold - Posts: 1,901
Posted: May 29, 2009 at 7:24 PM / IP Logged
http://www.caralarm.com/manuals/Omega%20-%20Generic/MAX-E.pdf
BatteryRED(+)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Ignition 1PINK(+)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Ignition 2WHITE(+)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Accessory 1ORANGE(+)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Starter 1YELLOW(+)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Anti-Theft TypeGM PASSLOCK IIŽ ANTI-THEFT SYSTEM
wiring diagram for an omega max e alarm -- posted image.Anti-Theft DescriptTHE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
wiring diagram for an omega max e alarm -- posted image.Key SenseLIGHT GREEN(-)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.Neutral SafetyYELLOW(-)IGNITION SWITCH HARNESS
wiring diagram for an omega max e alarm -- posted image.TachometerWHITE(-)LARGE HARNESS ON FRONT OF ENGINE
wiring diagram for an omega max e alarm -- posted image.Speed SenseDARK GREEN / WHITE(AC)AT PCM MODULE UNDER HOOD ON PASSENGER SIDE FIREWALL
wiring diagram for an omega max e alarm -- posted image.Parking LightsBROWN(+)AT VEHICLE LIGHT SWITCH
wiring diagram for an omega max e alarm -- posted image.Brake LightsWHITE(+)AT SWITCH ABOVE BRAKE PEDAL
wiring diagram for an omega max e alarm -- posted image.Reverse LightsLIGHT GREEN(+)IN HARNESS IN DRIVERS KICKPANEL
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: May 29, 2009 at 7:28 PM / IP Logged
< color=#008000>www.the12volt.com/installbay/uploads/D65_< color=#008000>max< color=#008000>-< color=#008000>e< color=#008000>.pdf -
tommy...
Gold - Posts: 1,901
Posted: May 29, 2009 at 7:30 PM / IP Logged
tommy...
Gold - Posts: 1,901
Posted: May 29, 2009 at 7:32 PM / IP Logged
HMMMM...Sorry for that garbled mess...The preview looked fine...Anyhow just use the search feature and your all set...!
steveosgrl7
Posted: May 30, 2009 at 8:16 AM / IP Logged
Thank you soo much!
steveosgrl7
Posted: May 30, 2009 at 8:40 AM / IP Logged
ok, at a road block... I have a purple wire and a royal blue wire on the harness, where do they go? The white wire seems to be the only wire that  triggers the horn, there is also a fuse on it. Is it the only power source out?
all you need in life is duct tape and zip ties
tommy...
Gold - Posts: 1,901
Posted: May 30, 2009 at 8:49 AM / IP Logged
If your referring to purple in pin 12...n/c...again if it is blue in 13 pin harness...no connection...Be more specific...the white on  the 4 pin harness is for parking lights
tommy...
Gold - Posts: 1,901
Posted: May 30, 2009 at 8:51 AM / IP Logged
Nevermind that post...Wrong install manual...but be more specific...what is the wiring desription of wire...
steveosgrl7
Posted: May 30, 2009 at 10:37 AM / IP Logged
The wiring harness is white and has 8 prongs. Need to know how to wire the harness to the car. Get power to the system but none of the functions are working. The sensor will not come on, and the system will not arm itself. Know the system works. If you need more info just ask.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
