remote start
thegreat22
Copper - Posts: 61
Posted: August 15, 2009 at 4:43 AM / IP Logged
So i just got the Clifford 50.7x installed. When i remote start it my air conditioning does not come on until i get in and turn the key. The radio comes ob though. Car is a 2001 mercury grand marquis.
(The Great)
Platinum - Posts: 13,725
Posted: August 15, 2009 at 5:31 AM / IP Logged
WIRECOLORPOLARITYLOCATION remote start -- posted image.
remote start -- posted image.BatteryBROWN OR YELLOW OR(+)LT.GRN IGNITION SWITCH HARNESS
remote start -- posted image.Ignition 1BROWN / PINK(+)IGNITION SWITCH HARNESS
remote start -- posted image.Ignition 2GRAY / YELLOW(+)IGNITION SWITCH HARNESS
remote start -- posted image.Accessory 1BLACK/ LIGHT GREEN(+)IGNITION SWITCH HARNESS(AC/RUN)
remote start -- posted image.Accessory 2PINK/BLACK
chev104275
Gold - Posts: 1,436
Posted: August 15, 2009 at 5:35 AM / IP Logged
sounds like you missed a ing or acc wire. How is the system wired ??
you should have these
Ignition 1 BROWN / PINK (+) IGNITION SWITCH HARNESS
Ignition 2 GRAY / YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 BLACK/ LIGHT GREEN (+) IGNITION SWITCH HARNESS(AC/RUN)
Accessory 2 PINK/BLACK
Posted: August 15, 2009 at 7:02 AM / IP Logged
So go back to the installers and point out where you live and have they heard of AC.  Know the Devil's in the detail  but I wouldn't dream of missing out any wires, too many anal customers, including one who recently reset the Valet code (4 digits, here) without realising on an alarm, then changed the programming,  came back to us complaining, said they would contact DEI and I told them they were welcome and to tell DEI what they'd done.
Chris Luongo
Platinum - Posts: 3,746
Posted: August 15, 2009 at 8:30 AM / IP Logged
Simple mistake.
The BLACK/ green second accessory wire would appear to only power non-essential items such as the radio and windshield wipers.
However, it also powers the clutch for the car's air conditioning compressor.
The installer simply has to power up the BLACK/ green accessory wire at the steering column (it's right with the other ignition and accessory wires)......even the slowest installer should be able to do this in less than 30-40 minutes.
NOTE: In the future, during remote start, your radio and windshield wipers will receive power. Be sure to switch off the wipers when parking the car, and you probably won't want to leave the radio on a loud volume setting.
