python 872
bennyhill007
Member - Posts: 7
Posted: October 06, 2009 at 8:17 PM / IP Logged
Would appreciate any trade install tips on a 96 Civic LX sedan.
t&t tech
Platinum - Posts: 2,622
Posted: October 06, 2009 at 8:47 PM / IP Logged
What exactly are you looking for help with? Remote start assistance or just basic alarm!
bennyhill007
Member - Posts: 7
Posted: October 06, 2009 at 11:09 PM / IP Logged
"the whole enchilada" Remote start + power locks + Power windows
t&t tech
Posted: October 07, 2009 at 7:11 PM / IP Logged
1996 Honda Civic Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+White Ignition Switch Harness
StarterBLACK/ White Ignition Switch Harness
IgnitionBLACK / YELLOW Ignition Switch Harness
Ignition 2Yellow Ignition Switch Harness
AccessoryWHITE/ Black Ignition Switch Harness
TachBlue Coil
Brake SwitchGREEN / WHITE Brake Switch
Trunk PinBlue/Black (-) Driver's Kick or behind Radio Light Green (-) Wire
Parking LightsRED / Black Driver's Kick Panel or above Fuse Panel
Head LampRED / White L And RED / Blue R at Steering Column
Door TriggerLight GREEN/ Red (-) Above Fuse Panel or behind Radio Green Connector
Door LockGREEN / WHITE (-) Driver's Kick Blue Connector or at Anti-Theft
Door UnlockGREEN/ Orange (-) Module behind Radio Green Connector Negative Trigger
Horn WireGray (-) Steering Column or Green Connector behind Radio
t&t tech
Posted: October 07, 2009 at 7:14 PM / IP Logged
That's the enchilada, half cooked!python 872 -- posted image.
bennyhill007
Member - Posts: 7
Posted: October 09, 2009 at 3:03 PM / IP Logged
What type of door lock systems does Civic uses? Type A? B? C? D? E? F? G? H?
t&t tech
Posted: October 09, 2009 at 5:20 PM / IP Logged
Type B, or negative trigger!
bennyhill007
Member - Posts: 7
Posted: October 25, 2009 at 6:57 PM / IP Logged
I want to only connect the starter kill and not the remote start. Which wires do I use on the H3 connector (9 pin)?
t&t tech
Posted: October 25, 2009 at 7:00 PM / IP Logged
what wires do you have on that harness?
bennyhill007
Member - Posts: 7
Posted: October 25, 2009 at 7:28 PM / IP Logged
1 PINK (+) IGNITION 1 INPUT/OUTPUT
2 RED / WHITE (30A) FUSED IGNITION 2 / FLEX RELAY INPUT 87
3 ORANGE ACCESSORY OUTPUT
4 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL WIRE)
5 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)
6 RED (+) FUSED (30A) IGNITION 1 INPUT
7 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
8 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
9 RED / BLACK FUSED (30A) ACCESSORY/STARTER INPUT
10 N/C N/C
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
