06 explorer tach
cmk0808ny
Copper - Posts: 203
Posted: October 14, 2009 at 4:41 PM / IP Logged
is there a tach wire inside a 06 explorer 4dr with the v8?
t&t tech
Platinum - Posts: 2,622
Posted: October 14, 2009 at 4:48 PM / IP Logged
Sure there is!
ckeeler
Gold - Posts: 1,461
Posted: October 14, 2009 at 5:32 PM / IP Logged
at any ignition coil, or fuel injector not gray or purple. the injector is the better place to pick it up at.
cmk0808ny
Copper - Posts: 203
Posted: October 14, 2009 at 6:08 PM / IP Logged
i meant inside the car under the dash or something. I know to go to the coil or injectors.
t&t tech
Posted: October 14, 2009 at 8:35 PM / IP Logged
Well! Go to the injectors! Geez!
ckeeler
Gold - Posts: 1,461
Posted: October 14, 2009 at 11:31 PM / IP Logged
yes for sure! thanks Darren.
ckeeler
Gold - Posts: 1,461
Posted: October 14, 2009 at 11:35 PM / IP Logged
if you want to spend that much time and effort, pull out the instrument cluster and test for the tach going into it there. but, it's much faster to just run it into the engine compartment (for me anyway, and thats soldering the connection and properly routing the wire and looming it as well).
yimke
Copper - Posts: 417
Posted: October 15, 2009 at 8:41 PM / IP Logged
no no. Remember the rule Chrysler-COILS ford-FUEL INJECTORS ONLY!
Chris Luongo
Platinum - Posts: 3,746
Posted: October 17, 2009 at 9:53 PM / IP Logged
I tested all the wires at an early (02-03) Mountaineer and never found tach.
The newer ones, however, have an anti-overcrank feature...just try it for yourself. Get in, turn the key to Start, and simply hold it there.....the starter will drop out as soon as the engine starts.
You could program your unit for voltage sensing, and set your cranking time for 1.5 or even 2.0 seconds, and the car should start every time.
Otherwise, you'd have to get tach under the hood.
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
