avital 4103 rear defrost wiring
swak
Member - Posts: 10
Posted: October 16, 2009 at 10:03 PM / IP Logged
Hello, I just had an Avital 4103 remote start installed on a 2009 Cobalt and the installer tells me the rear defroster cannot be connected without an additional relay and that the remote trunk release feature will then be sacrificed  Hope someone can confirm this is incorrect and tell us it's done.  thanks
chriswallace187
Gold - Posts: 1,661
Posted: October 17, 2009 at 4:14 AM / IP Logged
Your installer is mistaken. Read on...
You can view the Avital's manual here. On page 48 is half of the wiring pinout.
I can't think of any reason why your installer would have used something other than the "RED / White (-) 200ma channel 2" output for the trunk release, since it's designed primarily as a trunk release output.
For the rear window defogger, he'd use the "Blue/White 2nd status output/defogger" wire. This could be connected in one of 3 ways:
1. Directly to a wire from the defogger switch which goes to ground momentarily when the switch is pressed.
2. Directly to a wire from the climate control panel(if the defogger switch is integrated into it) or the defogger relay which activates the relay and stays at ground for as long as the defogger's active.
3. To an add-on relay which powers the high current wire going to the defogger grid itself.
Information on programming the defogger output wire(Menu 2, Option 8) is found from pages 32 to 40 of the PDF manual. For method 1 of connection that I've just stated, program the output to "pulsed". For methods 2 or 3 program it to "latched".
C Renner's Auto Electronix
swak
Member - Posts: 10
Posted: October 17, 2009 at 11:01 AM / IP Logged
Thanks, this is exactly what I thought since I had already seen the wiring diagram and saw separate connections for the trunk release the the rear defroster..  I expected that they would have hooked this up, why have the remote start if you can't melt the ice?
chriswallace187
Gold - Posts: 1,661
Posted: October 17, 2009 at 1:30 PM / IP Logged
Honestly I don't know anyone who does it unless asked, for a couple reasons.
First, many remote starts don't have the convenient dedicated defroster output that the Avital has.
Second, and feel free to check out the "Vehicle Wiring" link to see for yourself what I mean, unless the shop is paying big $$$ for ALLDATA or Mitchell they don't have a wire color or location for the defroster. So the installer has to figure the circuit out on his own, which takes time. I've done enough defroster hookups that it's not hard but I usually charge extra to make up for the time.
swak
Member - Posts: 10
Posted: October 20, 2009 at 10:57 AM / IP Logged
chriswallace187,
I showed my installer your answer and I think they will try your #1 solution for me.
NEW QUESTION:  I want the door locks to auto-lock / unlock  with the ignition switch, they tried to program it to do that and didn't get it to work yet, any ideas on that?
chev104275
Gold - Posts: 1,436
Posted: October 20, 2009 at 11:07 AM / IP Logged
the ignition lock and unlock are in menu 1 options 2 and 3
swak
Member - Posts: 10
Posted: October 20, 2009 at 11:24 AM / IP Logged
I think they tried that, should have mentioned that they added the power door locks, (car did not have factory power door locks).  The locks do work with the avital remote though so would that any difference?
chev104275
Gold - Posts: 1,436
Posted: October 20, 2009 at 11:35 AM / IP Logged
the locks would have to be tied into the avital system    if they are add on there should be 2 relays they can tie into for te locks to work
swak
Member - Posts: 10
Posted: October 20, 2009 at 11:50 AM / IP Logged
The avital remote does lock and unlock the doors including the horn beeps so the locks must be hooked up (maybe incorrectly ?).  Just didn't want to hear that only factory door locks would be able to do the auto  ignition locking.
chev104275
Gold - Posts: 1,436
Posted: October 20, 2009 at 12:36 PM / IP Logged
if the locks work with the remote then they should be able to change those settings to make it do what you want
Friday, September 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
