2009 dodge ram wiring
davezaner
Posted: November 07, 2009 at 8:17 AM / IP Logged
 dodge ram 1500 remote start wiring diagram for 09.
brhaugen
Copper - Posts: 275
Posted: November 07, 2009 at 8:58 AM / IP Logged
From Audiovox:
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED          (+)          BATTERY OR TIPM
               LOW CURRENT, FOR HIGH CURRENT APPLICATIONS GO DIRECTLY TO THE BATTERY
     Ignition 1          PINK/WHITE          (+)          IGNITION SWITCH HARNESS
               DO NOT USE FOR REMOTE START
     Accessory 1          DARK BLUE/PINK          (+)          TIPM, GRAY 40 PIN PLUG, PIN 26
               OR 12 VOLT POWER PORT DO NOT USE FOR REMOTE START
     Starter 1          YELLOW/GRAY          (+)          DK. GRAY PLUG IN FRONT OF TIPM OR TIPM, BROWN 40 PIN PLUG, PIN 1
     Speed Sense          DARK GREEN/ BROWN          (AC)          AT PCM MODULE UNDER HOOD ON PASSENGER SIDE, PIN 32
               PLUG TOWARDS DRIVER SIDE
     Parking Lights          WHITE/ LIGHT GREEN & WHITE/ VIOLET          (+)          TIPM MODULE UNDER HOOD
               TIPM MODUAL, BLACK 50 PIN PLUG (C7), PINS 50 AND 48
     Low Crr. Pk Lights          WHITE          (-)          VEHICLE LIGHT SWITCH, BLACK 10 PIN PLUG, PIN 1
               MUST USE 1K OHM RESISTOR FOR (-) PARKING LIGHTS
     Brake Lights          WHITE          (+)          STITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ RED          (+)          TIPM MODULE UNDER HOOD, GRAY 40 PIN PLUG, PIN 5
     Horn          DARK GREEN/ VIOLET          (-)          IN HARNESS AT STEERING COLUMN
               ALSO IN HARNESS TO INSTRUMENT CLUSTER
     Anti Theft RX          WHITE/ LT. GREEN          DATA          CAN HIGH
     Anti Theft TX          WHITE/ LT. BLUE          DATA          CAN LOW
     CANbus          CAN C BUS
     Rear Defrost          BLACK
               MUST ISOLATE FROM TIPM WITH RELAY
     Heated Driver Seat          LT. GREEN/ BROWN          (REV)          HEATED SEATS MODULE, 5 PIN PLUG (C2), PIN 4
     Heated Passngr Seat          LT. GREEN/ PURPLE          (REV)          HEATED SEATS MODULE, 5 PIN PLUG (C2), PIN 5
Brent Haugen
Fargo, ND
Chris Luongo
Platinum - Posts: 3,746
Posted: November 07, 2009 at 11:27 AM / IP Logged
The only feasible way to do a remote starter on those is going to be with a module from either ADS or Fortin.
www.idatalink.com
www.ifar.ca
Both sites allow you to read the installation guides online.
davezaner
Posted: November 09, 2009 at 6:50 PM / IP Logged
 Thanks good buddy.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
