2000 nissan maxima viper 560xv
winfred
Member - Posts: 22
Posted: November 15, 2009 at 9:57 AM / IP Logged
I am trying to install a Viper 560XV and use the horn instead of the siren. The siren output on the alarm is + and the horn wire is - how do I wire a relay up for this thanks. Car is a 2000 Nissan Maxima
Image is Everything
Posted: November 15, 2009 at 11:44 AM / IP Logged
Viper output to relay 86, ground to 30 and 85, car's horn output from 87. I don't know this unit but isn't there a secondary low current NEG horn output which you can programme to either constant or on-off alternating specifically for this function, hence if you connect at steering column, no need for a relay.
Posted: November 15, 2009 at 12:01 PM / IP Logged
Just checked, plug H4, brown, low curent neg horn output, RTFM
winfred
Member - Posts: 22
Posted: November 15, 2009 at 12:03 PM / IP Logged
Thanks I will try that don't know about the secondary  output
Image is Everything
wblakes
Copper - Posts: 202
Posted: November 15, 2009 at 12:04 PM / IP Logged
i think the 560xv has a constant 12v+ output for the siren wire. that won't work because you need a pulse output for horn and not constant. i guess you can do that by not using the siren wire but use the parking wire off the 560xv
wblakes
Copper - Posts: 202
Posted: November 15, 2009 at 12:06 PM / IP Logged
yeah or that
winfred
Member - Posts: 22
Posted: November 15, 2009 at 12:08 PM / IP Logged
What is RTFM?
Image is Everything
winfred
Member - Posts: 22
Posted: November 15, 2009 at 12:13 PM / IP Logged
Hey got it thanks alot for you guys help very greatful :o)
Image is Everything
wblakes
Copper - Posts: 202
Posted: November 15, 2009 at 1:17 PM / IP Logged
winfred wrote:
What is RTFM?
Read The F'ing Manual???
winfred
Member - Posts: 22
Posted: November 15, 2009 at 1:22 PM / IP Logged
ok ok got it
Image is Everything
