2003 Chevy Suburban Alarm/Remote Start
BulletTooth
Copper - Posts: 122
Posted: April 04, 2003 at 12:35 AM / IP Logged
What's up guys I need the wiring diagram for the 2003 Chevy Suburban please.
And any info on what I could do if the DEI part #456G for the Doorlocks is not available? What does the directfax document #1601 say? Thank you very much in advance.
Platinum - Posts: 12,488
Posted: April 04, 2003 at 12:41 PM / IP Logged
|              12V|red & RED / white     |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #456G *3       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |driver rear door harness    |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|gray/black          |   |headlight switch            |
|       HEADLIGHTS|pink or white       |-  |headlight switch            |
|     DOOR TRIGGER|*1                  |-  |*1                          |
| DOME SUPERVISION|comes on with disarm|   |                            |
|  TRUNK/HATCH PIN|pink/black          |-  |harness to BCM *2           |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|NOT pink            |   |any fuel injector           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black or blk/yel    |-  |column or gray plug @ BCM *2|
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |LF window switch in door    |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |RF window switch in door    |
|  LR WINDOW UP/DN|blue - brown        |A  |LR window switch in door    |
|  RR WINDOW UP/DN|blue - brown        |A  |RR window switch in door    |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L.  *1 The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fusebox leading to the BCM rear plug. Use all four wires and diode isolate each.  *2 The BCM (Body Control Module) is located behind the headlight switch.  *3 If Directed module part #456G is not available, refer to directfax document #1601.  Upper trim level vehicles may have a door lock switch on the right rear panel.  If present use white (-) for lock and lt. blue (-) for unlock.
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1601.pdf
blackmax91
Posted: April 07, 2003 at 11:11 AM / IP Logged
What about the windows, I have an Clifford Avant Guard 4 and trying to wiring the windows. I windows shows a 12V current with a Neg. trigger, is theirs a wiring diagrams for it. 2000 Chevy Tahoe New body style.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
