99 escort zx2
coolen
Copper - Posts: 121
Posted: December 26, 2009 at 7:32 PM / IP Logged
Good evening to all. I'll be installing a CT-3271 prostart, on a 99 ZX2 Manual tranny. I noticed that there are 2 fused power wires on this unit which need to be powered. In the harness for the ignition switch there is a large green wire that is 12v at all times. Do I connect both power wires to this one wire?
Is there anything else I should be aware of here?
Unit Schematic: http://www.engines911.com/asdocs/CT_3271_wd_en_h46s40_080908.pdf
Ford Schematic: https://www.the12volt.com/installbay/alarmdetail/846.html
There was no listing for a 99 ZX2, but there was for a 98. I'm going by the 99 Excort diagram, should I go by the 98ZX2 diagram?
Thanks to all
Platinum - Posts: 13,726
Posted: December 26, 2009 at 7:58 PM / IP Logged
According to Audiovox, any 2 door escort is a zx2    Remote start info
99 escort zx2 -- posted image.BatteryBLACK(+)IGN SWITCH HARNESS BASE OF STEERING COLU
99 escort zx2 -- posted image.Ignition 1BLUE(+)IGN SWITCH HARNESS BASE OF STEERING COLU
99 escort zx2 -- posted image.Ignition 2BLACK/ WHITE(+)IGN SWITCH HARNESS BASE OF STEERING COLU
99 escort zx2 -- posted image.Accessory 1BLACK/ RED(+)IGN SWITCH HARNESS BASE OF STEERING COLU
99 escort zx2 -- posted image.Starter 1RED / WHITE(+)IGN SWITCH HARNESS BASE OF STEERING COLU
99 escort zx2 -- posted image.Anti-Theft DescriptNONE
99 escort zx2 -- posted image.Key SenseBLACK/ PINK(-)STEERING COLUMN HARNESS
99 escort zx2 -- posted image.Neutral SafetyNOT GROUNDING
99 escort zx2 -- posted image.TachometerYELLOW/BLUE(-)OR RED / LT.BLU OR BLU/LT.GRN(COIL 2 CYL)
99 escort zx2 -- posted image.Speed SenseWHITE/ BLACK 8000(AC)PASS SIDE OF CONSOLE 104 PIN CONN POS 58
99 escort zx2 -- posted image.Parking LightsRED / BLACK(+)15 PIN GRN CONN BELOW FUSE BOX
99 escort zx2 -- posted image.Brake LightsGREEN(+)AT BRAKE SWITCH
99 escort zx2 -- posted image.Reverse LightsRED / DARK GREEN(+)20 PIN CONN IN DR. KICK PANEL
99 escort zx2 -- posted image.HornGREEN/ ORANGE(-)AT STEERING COLUMN
Alarm Info
99 escort zx2 -- posted image.All Door TriggerRED / WHITE(-)UNDER FUSE BOX99 escort zx2 -- posted image.
99 escort zx2 -- posted image.LF LatchVIOLET/WHITE(-)AT FRONT LEFT DOOR SWITCH
99 escort zx2 -- posted image.RF LatchVIOLET/WHITE(-)AT FRONT RIGHT DOOR SWITCH
99 escort zx2 -- posted image.Trunk TriggerRED / YELLOW(-)DRIVER'S KICK "LARGE HARNESS"
99 escort zx2 -- posted image.Alarm DisarmN/A
Posted: December 26, 2009 at 7:59 PM / IP Logged
Door Lock info
99 escort zx2 -- posted image.Power UnlockBLUE(-)NEGATIVE TRIGGER99 escort zx2 -- posted image.
99 escort zx2 -- posted image.PowerLockGRAY(-)DRIVERS KICK OR PASS KICK
coolen
Copper - Posts: 121
Posted: December 27, 2009 at 2:48 PM / IP Logged
Thanks for the info. All seemed to go well until I went to learn the module to the tach. Now, when I ran my tach wire, I did so the same way as I did my truck, right behind the instrument cluster at the guage. This unit is not recognizing the tach, and until I figure that out, I am unable to go any further.
Suggestions?
Posted: December 27, 2009 at 2:53 PM / IP Logged
Are there any one of the 3 colors listed above on either of the ignition coils?
coolen
Copper - Posts: 121
Posted: December 27, 2009 at 3:09 PM / IP Logged
This is the info I have found :
http://www.teamzx2.com/showthread.php/9996-Tach-signal?p=169188
That site says he tach learns his zx's on the wire on the right hand side of the coil wires.
http://www.teamzx2.com/showthread.php/252-Remote-Start-and-Keyless-Entry
This site has a pic of where to connect for the tach. And it isn't the far right, it's the left.
coolen
Copper - Posts: 121
Posted: December 28, 2009 at 5:51 PM / IP Logged
Thanks for the replies thus far. I got everything geared up as per the instructions. I don't have the clutch bypassed as of yet.  However I figured that the starter would start the car if i had the clutch pushed in-but no. Park lights flashed once, and that was it. I double checked all my wiring, and went through the troubleshooting section of the manual. I'm fairly certain that it isn't in valet mode, but I'll double check that again tomorrow. What could I be missing here? Everything else went well, as far as programming the remote to the unit, tach learn, and ready mode is concerned.
Thanks in advance
tedmond
Gold - Posts: 4,610
Posted: December 28, 2009 at 6:14 PM / IP Logged
if parking lights flashed once, do you hear multiple clicks from the unit (brain)? if you hear multiple clicks, that means its trying to start(notice cluster lights). if its just one click, pause then another click  and you see the parking lights only, its in valet mode.
the parking lights car also be used as diagnostics. check pg 24 of your installation manual.
Ted
Compustar Expert
coolen
Copper - Posts: 121
Posted: December 28, 2009 at 6:46 PM / IP Logged
The lights will flash once, as in it's telling me it's recieving the signal ok- but that's all it's doing. That's why originally I thought it was in valet mode. After it clicks once, no dash lights flash up or anything. In my truck, after the initail click, the dash lights flash up and away it goes. I double checked all the wiring and it all seems ok. Unless I'm missing something that has to be hooked up for the locks n' such, because I didn't wire any of that up.
