need tech sheet for 97 Supra TT
michaelrc51
Member - Posts: 22
Posted: April 07, 2003 at 7:05 PM / IP Logged
I need an installer tech sheet for a 97 Toyota Supra TT 6-speed for an alarm. I am going to install a Clifford Avantguard 4 on my supra, and the alarm has a lot of wiring, Also, are there any recommendations on how to use my HKS turbo timer with the alarm? Is it necessary to use a relay for the nuetral safety switch, or should I just complete the curcuit?
CCRoadshop
Copper - Posts: 70
Posted: April 07, 2003 at 11:58 PM / IP Logged
heres your alarm diagram
12 volts - white & wht/red  (+) polarity  found running to steering column
ignition - BLACK / YELLOW    (+)  polarity  found running to steering column
Starter -  BLACK/ red   (+)  polarity  found running to steering column
Power lock - GREEN/ YELLOW  (-) polarity            found in passenger kick panel
Power unlock - white   (-) polarity      found in passenger kick panel
Parking Lights - Green  (+) polarity   found in the  drivers kick panel   (white plug bottom of fuse box)
Door Trigger - RED / black  (-) polarity found in the drivers kick panel (trunk trigger should tie in with this wire
If you have a factory alarm u should be all set becuz in most toyotas the factory alarm will arm/disarm with lock/unlock
hope this helped
Installer - Circuit City Roadshop(2 1/2 years n counting)
Alpine CDA7894(soon to be the cda9815)
Pioneer XM unit(soon to be direct link alpine)
Audiovox 995C alarm/remote start
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
