viper 5901 12volts
eghatchie
Posted: January 29, 2010 at 6:59 PM / IP Logged
Just install a 5901 viper alarm to my 1997 honda civic ex..................got the remote start to work and everything But im still having some problems.......can 12volt help out ..................thanks
Problems
1-Headlight and taillights not blinking when arm and disarmed (10a fuse in the cpu is on)
2-Cliclimate control not working unless key is in the ignition
3-Having alot of left over wires
heres the diagram of the viper 5901 alarm/remote starter
https://img6.imageshack.us/img6/276/img0199m.jpg
i circle all the wiring that i couldnt fix and need help with
H1/4- WHITE/ BROWN PARKING LIGHT ISOLATION WIRE pin 87a on onboard rly (what is this wire for and do i need it)
H1/9- BLACK/ WHITE (-) 200mA DOME LIGHT SUPERVISION OUTPUT (cant find the wiring does anyone know were it located)
H1/10- WHITE/ BLUE (-) REMOTE START/TURBO TIMER ACTIVATION INPUT  (what should i do with is wire)
H1/11- WHITE PARKING LIGHT OUTPUT ( what is this wire used for and were can i find it.........in a honda civic 97 ex)
       Is this the reason why my tailligh and headlight arent blink when i arm or disarm the car
H3/7-  PINK/WHITE (+) IGNITION2/ FLEX RELAY OUTPUT (What i this wire used for)
h3/8 PINK/BLACK (+) FLEX RELAY INPUT 87A KEY SIDE ( What is this wire used for)
H2/11 to H2/14 on the chart what are these wire used for and do i need them
also car that the alarm is going in to is a 97 honda civic ex 5 speed
EgHatchie
t&t tech
Platinum - Posts: 2,621
Posted: January 29, 2010 at 7:08 PM / IP Logged
WHITE/ brown- unused
BLACK/ white- unused
WHITE/ blue- unused
white- this is your parking light wire, and also the reason yoru lights aren't blinking with the alarm!
Pink/white- ignition 2!
Pink/black- unused!
The h2 harness wires you refer to are also unused!
t&t tech
Posted: January 29, 2010 at 7:09 PM / IP Logged
Constant 12V+ White  Ignition Switch Harness
Starter BLACK/ White  Ignition Switch Harness
Ignition BLACK / YELLOW  Ignition Switch Harness
Ignition 2 Yellow  Ignition Switch Harness
Accessory WHITE/ Black  Ignition Switch Harness
Tach Blue  Coil
Neutral Safety Wire BLACK/ Blue (-)
Brake Switch GREEN / WHITE  Brake Switch
Trunk Pin Blue/Black (-)  Driver's Kick or behind Radio Light Green (-)
Parking Lights RED / Black (+)  Driver's Kick Panel or above Fuse Panel
Head Lamp RED / White left.  RED / Blue right at Steering Column
Door Trigger Light GREEN/ Red (-)  Anti-Theft Module behind Radio Green Connector
Door Lock GREEN / WHITE (-)  Above Fuse Panel or at Anti-Theft Module
Door Unlock GREEN/ Orange (-)  Behind Radio Green Connector
Horn Wire Gray (-)  Steering Column or Green Connector behind Radio
Windows Up LF=RED / Yellow, RF=Blue / YELLOW, LR=GREEN/ YELLOW, RR=Yellow
Windows Down LF=RED / Blue, RF=Blue/Orange, LR=Green, RR=YELLOW /GREEN
eghatchie
Posted: January 29, 2010 at 7:13 PM / IP Logged
so all i need to do is run h3 pink/white wire to the h3 RED / white and that it
and the viper 5901 comes with a 12mins remote start time how can i ajust that
EgHatchie
t&t tech
Posted: January 29, 2010 at 7:20 PM / IP Logged
No the pink/white would connect to the ignition 2 wire in the car which is yellow like i posted above!
To adjust the runtime
Turn ignition on the off
press and hold the valet switch until you hear three chirps
then press the valet switch 5 times hold on the fifth press
there are three settings
1chirp setting- 12mins (default)
2 chirp- 24mins
3 chirp- 60 mins (Which is really overkill in my opinion!)
