testing alarm outputs
monty862
Copper - Posts: 116
Posted: February 27, 2010 at 11:43 PM / IP Logged
I was wondering if I can test an input by grounding it to see if the alarm wil sound. I have a Viper 5901 that I'm having trouble getting to work with my door triggers. Can I ground the green negative door trigger wire H1/8 directly to the vehicle ground to test it. It shows constant 12 volts whether armed or disarmed.
Platinum - Posts: 13,726
Posted: February 28, 2010 at 12:25 AM / IP Logged
If it is the negative door trigger wire, yes grounding it should make the alarm go off.  What kind of vehicle do you have.  Some vehicles have door trigger systems that fail.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: February 28, 2010 at 1:12 AM / IP Logged
Just in case, make sure you disconnect it from the factory wire prior to grounding it. That way if you accidentally got the wrong wire you won't do any damage.
monty862
Copper - Posts: 116
Posted: February 28, 2010 at 1:15 AM / IP Logged
Its a 2010 Fusion. I have a thread on here about my install, but have had no replies on this for several days. I didn't want to start another thread, but I thought this might be considered a new issue. All the other triggers are working. Hood pin, trunk trigger and shock sensor all will sound alarm when triggered. All four door trigger wires are diode isolated with the bands towards the SJB. I tested all diodes before and after attaching to the trigger wires. I show resistance when the door is closed and open circuit when door is open. The message center on the dash is still functioning properly and will identify which door is open.
Posted: February 28, 2010 at 1:25 AM / IP Logged
Audiovox has the following info for your vehcle.
All Door Trigger GRAY/VIOLET (+) AT SMART JUNCTION BOX BEHIND DRIVERS SIDE OF DASH ABOVE KICKPANEL
the note reads: SJB 14 PIN GRAY CONNECTOR PIN#9
monty862
Copper - Posts: 116
Posted: February 28, 2010 at 1:39 AM / IP Logged
Thanks. I just grounded the green H1/8 and the alarm did not sound. Do you think I should try using the positive trigger wire you listed with the purple H1/6 instead or see about replacing the 5901 module?
mikvot
Gold - Posts: 1,043
Posted: February 28, 2010 at 1:53 AM / IP Logged
 You sort of answered your own question in a way.
An open circuit, which all newer Ford door triggers are, is neither a (+) or (-)  I always use the domelight...in your case the Grey/violet (+).It will have a delay, so if your system has a setting to ignore the open door for a period of time, you will need to set it.
monty862
Copper - Posts: 116
Posted: February 28, 2010 at 1:57 AM / IP Logged
Thanks. Wonder why the DEI install sheet shows these four "trigger" wires, color and location? And any clue why it still didn't sound when I grounded the wire? testing alarm outputs -- posted image.
mikvot
Gold - Posts: 1,043
Posted: February 28, 2010 at 2:00 AM / IP Logged
I was wondering the same thing.....did you allow the alarm enough time to set up?
monty862
Copper - Posts: 116
Posted: February 28, 2010 at 2:01 AM / IP Logged
I didn't know there was any set up time. I hit arm and grounded the wire within 30 seconds.
Page of 3
