02 ram , viper 5601
kenerly
Member - Posts: 13
Posted: February 28, 2010 at 4:23 PM / IP Logged
Trying to install this alarm in my 02 dodge ram 2wd auto (black keys)
When I hit the start button on the remote, I get no start. The parking lights flash 8 times (install guide states that this means, neutral safety wire has no ground or the neutral safety switch is off)
I have even grounded the neutral safety wire coming from alarm to no avail.
Any idea?
tedmond
Gold - Posts: 4,610
Posted: February 28, 2010 at 6:34 PM / IP Logged
you need to ground it, and have the nss switch plugged in, and turned to on.
Ted
Compustar Expert
kenerly
Member - Posts: 13
Posted: February 28, 2010 at 6:56 PM / IP Logged
That is how I have it. Switch plugged in turned to on, BLACK/ white wire grounded.
kenerly
Member - Posts: 13
Posted: March 01, 2010 at 3:03 PM / IP Logged
I got that problem fixed, bad neutral switch (the one that comes with the alarm).
Now hit start button, dash lights come on, fuel pump comes on, no starter engage. If I put the keys in the ign, turned to ign, the remote start works.
What am I missing?
tedmond
Gold - Posts: 4,610
Posted: March 01, 2010 at 4:38 PM / IP Logged
you are missing power to a secondary ignition wire.
power up the flex relay and use that for ignition 2
Ted
Compustar Expert
kenerly
Member - Posts: 13
Posted: March 01, 2010 at 7:05 PM / IP Logged
I'm confused. Does the RED / black H3/9 30a fused accessory/starter relay input alarm wire need to be hooked to 12v constant?
same for the H3/2 RED / white 30a fused ign2 / flex relay input 87 ?
When I hook H3/2 to constant 12v, the H3/7 pink/white ign 2 flex relay output shows 12v constant regardless of the alarms state.
kenerly
Member - Posts: 13
Posted: March 01, 2010 at 7:15 PM / IP Logged
Also if I give 12v constant to the H3/9 RED / black alarm wire the starter engages on its on. No keys in ign, no touching key fob?
kenerly
Member - Posts: 13
Posted: March 03, 2010 at 8:09 AM / IP Logged
Any ideas folks?
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
