viper dei 5902 confusing
sacredcreationz
Member - Posts: 21
Posted: March 21, 2010 at 6:38 PM / IP Logged
Well this promises to be a long post for everyone.  To start, the name is Kris, I am new to the forum but not new to elctronics.  I build my own computers, install car audio and in the past I have done security.  I am currently designing the wiring harness for a two place Jet.  Anyways, I thought I would get an alarm for my car, did some research and some shopping and got:
1. Viper 5902 Remote start alarm with colored remote screen-  This system is identical to the 5901 but the remote is color.
2.  DEI 545 Nite Light system- In order to make the car lights on at night and it has a longer timer for when I shut off the car. Also allows daytime running of my lights.
3.  DEI 506T Glass break sensor-  I plan to have tint so proximity is a no-go and the 5902 comes with a shock.
4.  DEI 522T Trunk release Solenoid-  Dissapointed in it's lack of strength and the fact it doesn't come with a relay, instead they send it with a switch only.
5.  DEI 689M Nuetral start module-  Not thinking I am going to use this.  Not to mention I am wized at their installation drawing.  Completely worthless.
6.  DEI 516L Voice control siren(progammable)-  Love the PA ability, bought to add voice to the arm. disarm, warn and full trigger outputs to make the car stand out so not everyone will ignore it in the parking lot.
7.  DEI 530T 2 Window automation-  My car is a coupe and I want them to roll up when I arm the car.  Other features are nice like, one touch up and down windows.
8.  DEI 529T 1 Window automation- Sun roof control.
This is all going in a 1999 Mitsubishi Eclipse GS with a manual Transmission.  Now the reason for this posting.  I was perturbed to find my installation manual consisted of a quick start guide and operational manual.  I went to Directech.com only to find that they will not supply anyone other than their techs.  Well then why the heck was I allowed to buy it from buy.com????? Since then I have been bugging the internet for Directech passwords or installaion manuals posted in .pdf's.  I stumbled across the install manual for the 5901 only to find that it may not show the right connectors but the pinout scourcing and reasoning is the same.  Follow this link for that install manual:  http://www.directeddealers.com/manuals/IG/Viper/N5702V_2008_08web.pdf
But that can only help a person out so much.  So here comes the list of questions;
1.  wth is this Flex relay?  and why not just call it an aux relay that is integrated in the 5902 housing.  I need to know what amperage it can handle if I am going to use it.     I will tell you that so far I have figured it to work like (in terms of a standard automotive relay) this:
           85-      5902 module controlled.  The module provides it's own ground, whether for trigger or constant.
           86-      5902 module controlled.  The module provides it's own 12v+, whether for trigger or constant.
           87-      H3-2 (connector H3, pin 2) Labeled as "(+) FUSED (30A) Ignition 2/ Flex relay input 87".  What I don't understand, is it ignition 2 because you can program the flex relay to be that or is it ignition 2 and split power scource with whatever you have on the flex relay? Why is it labeled as 87 if it is the input for the relay.  Relay inputs are usually pin 30 unless you are using two scources for one output.  The install manual for the 5901 says "this wire is the polarity feed for the ignition 2/flex relay."  Not that that helps...
           87A-    H3-8.  Labeled as "(+) Flex relay input 87A key side (if required) of flex relay". Homo say what?!?!  This one doesn't make any sense.
           30-      H3-7    Labeled as "Ignition 2/ Flex relay output".  I would have to guess this is what you get out depending on the state of the flex relay and what is attached to 87 and 87A?
Someone please tell me what is going on with this flex relay.  Using it or not I would like to know what it does and why i have it.
More questions in next post.
sacredcreationz
Member - Posts: 21
Posted: March 21, 2010 at 7:07 PM / IP Logged
2.   on H2-10 is the "(-) remote start / turbo timer activation input".  What is this in lamens terms?  according to the install manual for the 5901 it says "this input comes from the factory set to 1 activation pulse.  This means that it is necessary to have a single ground pulse on the WHITE/ blue wire for the remote start to activate or to deactivate."  Do I need to ground this in order to start.  I would like to think that is what the book said but I have been reading posts on here and HOWIEII is telling people that it is not needed and thier cars start so I am confused.
t&t tech
Platinum - Posts: 2,616
Posted: March 21, 2010 at 8:45 PM / IP Logged
Another long thread! Woooohoooo! viper dei 5902 confusing -- posted image.
That WHITE/ blue is unused! It's purpose is to trigger the remote start via a source other than the control unit, Example a another unit or push to start button!
The flex relay is used when the ignition switch requires isolation, which isn't the case of your eclipse! I think!
All the fused thirty amp wires go to a proper twelve volt source!
More answers in next post!
commit your way to jehovah and he will act in your behalf. psalms 37:5
sacredcreationz
Member - Posts: 21
Posted: March 23, 2010 at 11:48 PM / IP Logged
ok folks all installed.  remote start doesn't work.  First offI had to get into the programming mode and luckily I had the instruction set from the 5901 to figure that out.  But here is the problem.  I can get the remote start to activate, via raising the parking brake tapping the brake and then hitting the remote start button on the keyfob.  It activates as it should and so I turn off the car (the Viper 5902 keeps the car running), pull out my keys, open the door shut it and then lock it.  The car shuts off like it is supposed to and tells me that it is ready for remote start.
So I hit the button to start it.  The power comes on and I can hear the relay that i figured was the starter relay click but nothing.  Nows here is the set up.
99 mitsubishi eclipse gs.  First alarm install for the car. The alarm is the DEI Viper 5902.  I have alot of other modules but I have not gotten to those.  wireing wise
H1/1 -trunk release- Goes to the negative side of a relay I put in for the solenoid I put in. Relay is using this input of gnd as switch.  Relay has constand power to coil and to common. Out put of relay goes to solenoid.
H1/2 -12V input- Is wired to inline Fuse, 10 amp, then to buss bar I made of copper.
H1/3  -siren output-  Through the stock grommet above the drivers kick panel, though the drivers fairing panel and to the siren mounted next to the radiator fan. + red wire at the siren
H1/4 -parking light isolation-  Not used
H1/5 -Ground- um yeah, this one went to ground. There is a grounding post underneath the enviromental ducting in the center console.  I grounded with a ring terminal.
H1/6 -Pos Door trigger-  NA My doors are (-) triggers
H1/7 -Trunk Pin-  This wire is tied to the GRN/RED wire behind the side panel for the rear passenger on the drivers side.  There is a relay for the door locks and the old remote keyless entry control module there. I found the trunk wire as a ptg NO in the wire bundle there and taped in because I didn't want to make a mess of my drivers kickpanel.
H1/8 -Door trigger (-)- This was behind the Drivers rear side panel.  The framing of the car is open and you can get to the door pin.  The wire is Grn/Red.
H1/9 -Dome Light Control-  I tied into the Blk/Blu wire at the top of the power control box with the fuses just inside the drivers kick panel.  At the top there is a small four pin plug with three wires.  Domelight uses a (-) as control.
***H1/10 -Remote Start/Turbo timer activation-  Now against better judgement I did NOT connect this wire to anything.  According to the install book for the 5901, "It is necessary to have a single ground pulse onthe white blue wire for the remote start to activate or to deactivate."      So could this be my problem?????
H1/11 -Parking Light output- The 5902 comes with a mini fuse inside a removable cover on it's brain.  I set my fuse up on the (-) circuit because my light use a negative feed. I got the wire from the connector on the steering column.  Can't remember the color and I didn't right it down.
H1/12 -Ground when Armed- No connection at this time but for all my other modules later.
That was connector H1.
KPierson
Platinum - Posts: 3,527
Posted: March 24, 2010 at 6:55 AM / IP Logged
Did you bypass the clutch properly?
Try the same routine again, but instead of  getting out of the car stay in it.  After the car shuts down and is ready to remote start push the clutch in and remote start the car.
This is the exact reason that DEI only supports dealers - these are fairly complexed systems and there are quite a few options and lots of flexibility.  Chances are you bought from a supplier who is not licensed to sell DEI products and you most likely have no warranties through DEI on any of the products you purchased.
Kevin Pierson
sacredcreationz
Member - Posts: 21
Posted: March 24, 2010 at 12:19 PM / IP Logged
H2/1 -Alarm disarm output-  Now my eclipse has a simple system.  If you lock the doors from the outside ad then open the car from the inside without unlocking, (ie the windows are down), then the horn starts to honk and wont stop till you unlock the car with the keys.  But I still didn't think I needed this hooked up.
H2/2 -Aux 4 output-  No Conn.
H2/3 - Alarm arm output- Same instance as disarm, no conn.
H2/4 -Aux 2 output-   No Conn.
H2/5  -Aux 3 output-   No Conn.
H2/6  -Aux 1 output-   No Conn.
H2/7  -Diesel wait to start-  I cut this wire shorter and heatshrinked the tip so there is no way this is getting ground.  No Conn.
H2/8  -Horn Honk Output-  No connection
H2/9  -Tach input-  I ran this wire to my ignitor coil pack.  It has three wires, one is larger than the other two.  One is constand supply voltage, the bigger one, so I connected the alarm lead to one of the smaller wires.
H2/10  -Status output-  I wired this to my clutch wire.  The clutch wire uses a Normally open switch and passes ground through it. So I wired to the signal side before the switch.
H2/11  -Flex relay control out-  No Conn.
H2/12  -Accessory Out-  No Conn
H2/13  -Starter Out-  No Conn
H2/14  -Ignition 1 Out-  No Conn
H2/15  -Hood pin input)  Went through the firewall through the grommet for the wireing harness above the drivers kickpanel, then through the drivers fairing, to the existing hood switch.  It uses Gnd in a normally closed state.
H2/16  -2nd Status/ Rear defrost- This wire is hooked to the Rear defrost switch on the dash.
H2/17  -Brake shutdown-  This wire is a positive lead when the brakes are applied.  I used the wire coming of the brake switch just above the brake pedal.
H2/18  -Nuetral Safety Input-  Simply put to the parking brake when sends ground when applied.
sneakycyber
Silver - Posts: 413
Posted: March 24, 2010 at 12:57 PM / IP Logged
Did you plug in the on off switch and turn it to the on position. It wont start without the switch installed.
sacredcreationz
Member - Posts: 21
Posted: March 24, 2010 at 1:30 PM / IP Logged
Kpierson- Don't get on here and get all high and mighty on me.  I paid for the system fair and square and all i ask is a true installation guide.  Not some humbo jumbo crap written in their tech talk that only they understand.  And if that is the case then don't make it availiable to the pupblic.  Wanna jknow where I got it?  Buy.com  Simple.  A place anyone can get it.  So DEI needs to step up to the plate and correct thier own problems before they become some.  I would have love to bought something else had I known they were so proprietary.
You see I design the electrical systems on jets and I am fully capable of researching in order to accomplish my task.  As per your question on the clutch, yes I did do that.  I did alot.  here is a list
-Thought the car my have theft in lock phase so I unlocked the car first, didn't open the door cause I was actually in it.  pushed in the clutch  and set the key in the ignition so if the car had security it would think that I was in the car. The power comes on and then nothing.  I am just short of spending the time to trace the wires.  I have a schematic but it is not very reliable.  And it should be working.  Here is another interesting point.  When I did what I said above with staying in the car, pushing in the clutch, having the key in,  I  had also striped the wire going to the starter relay, (starter side) and attached a wire via aligator clip, (not smart but temperary) from the power supply contant and that start wire.  Still nothing when the car was trying.  But as soon as it failed I would unlock the car open the door like i got in and push in the clutch and attach that wire and sure enoughthe car would start turning over.  It wouldn't run cause no power to acc or ignition.
Unless you are going to help please do not bother to post. I can here for help.  I am not ignorant or arrogant I bought a system because I believed I would get proper information on that system.  I do everytime I buy something in the aircraft industry after market or not.
sacredcreationz
Member - Posts: 21
Posted: March 24, 2010 at 1:39 PM / IP Logged
SneakyCyber-
Yes the nueatral saftey switch is pugged in and in the on position.  I tested it in the off position and the alarm will say Remote Start not Availiable.
KPierson
Posted: March 24, 2010 at 2:18 PM / IP Logged
I was not trying to be high or mighty, I was simply explaining that you bought a product from a "shady" source and that what you bought is designed to be installed by a TRAINED installer and therefore the installation documentation is extremely limited.  THEY DO THIS ON PURPOSE.  Furthermore, in your owners manual it states that the product MUST be installed by an authorized dealer and therefore they have NO obligation nor reason to provide you with any installation documentation nor support.
My advice to you would be to return the DEI products and purchase something that is geared towards a DIY'er or take the car to an authorized installer and pay to have it done right.
Kevin Pierson
Page of 3
Friday, August 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
