06 jeep wrangler issue
au5599
Copper - Posts: 95
Posted: March 29, 2010 at 4:45 PM / IP Logged
Ok I got a customer who has an 06 jeep wrangler and he wanted to be able to tow it behind his RV. He has a 7pin connector on the RV. He has a coil adapter that changes into a 6 pin round. He had towing lights on there and they worked fine.
So we run wiring front to rear of the jeep. 6 pin connector up front. Tie into factory wiring in rear just as it goes down the body grommet. Wired right turn to BROWN / red, left turn to GREEN/ red, parking lights to WHITE/ yellow. Grounded right there. Also did 4 pin connector there as well.
Now the issue is, turn signals worked but when parking lights are on they start flashing like you got hazards on.
I only have limited time and certain days to play with it. So has anyone done this and know of a fix? Thought about diode isolating it but not sure if that will take care of the problem.
Street Dreams Car Club
93 GRAND CARAVAN SE / Astro
Team New York SS3-4 06 & SM3-4 07 DB Drag World Finals
2003 Chevy Suburban LT / 98 GTP
tedmond
Gold - Posts: 4,610
Posted: March 29, 2010 at 4:49 PM / IP Logged
yes you need to diode isolate the wires.
Ted
Compustar Expert
au5599
Copper - Posts: 95
Posted: March 29, 2010 at 4:56 PM / IP Logged
But should I also do the factory wires with diodes or should that be fine and just the new wires.
au5599
Copper - Posts: 95
au5599
Copper - Posts: 95
Posted: March 29, 2010 at 4:57 PM / IP Logged
tedmond
Gold - Posts: 4,610
Posted: March 29, 2010 at 6:44 PM / IP Logged
isolate new and factory wires so they do not backfeed on one another.
Ted
Compustar Expert
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
