parking light flashing setup
nitro71
Member - Posts: 15
Posted: June 30, 2010 at 12:39 PM / IP Logged
I'm almost done hammering out the basics on this install. 97 Dodge Ram Van, automatic. Avital 5103 system.
Working on the parking lights flashing. I'm unsure if I need a relay or not. The manual makes it sound like you can go up to 10 amps draw when using the negative output.
Any insight is appreciated.
nitro71
Member - Posts: 15
Posted: June 30, 2010 at 12:47 PM / IP Logged
Since my lights are on a positive circuit the Avital manual says it is a 200ma output. Would seem I will need a relay?
dasbogie
Silver - Posts: 514
Posted: June 30, 2010 at 1:11 PM / IP Logged
is there a jumper you can move on the avital brain box to select positive output?
Advanced
nitro71
Member - Posts: 15
Posted: June 30, 2010 at 3:02 PM / IP Logged
Yes there is. Already set it to positive. Just was trying to figure out how many amps it's good for and if I need a relay to power the warning lights.
nitro71
Member - Posts: 15
Posted: June 30, 2010 at 3:44 PM / IP Logged
Anyone know how many amps the positive output is good for on the DEI/Avital parking light circuit? Each lamp is .59 amps. That's pretty thick wire it has coming out of the unit.
dasbogie
Silver - Posts: 514
Posted: June 30, 2010 at 5:15 PM / IP Logged
10 amp, is there not a 10 amp fuse inline with the white parking light wire?
Advanced
nitro71
Member - Posts: 15
Posted: June 30, 2010 at 6:10 PM / IP Logged
Thanks! Yes there is a fuse. The wording in the manual made me a little confused. Appreciate the help!
jcs091570
Copper - Posts: 155
Posted: July 01, 2010 at 1:38 AM / IP Logged
Just check your vehicle auto fuse for your parking light system..it shouldn't be any more than 15 or 20amps.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
