2010 vw jetta ignition harness
captain d2
Member - Posts: 8
Posted: September 13, 2010 at 1:21 PM / IP Logged
Hi everyone. Been looking through these forums for a method of removing that black box from the steering column. There is no way that there is only the one torx screw holding that thing on. It seems like there are connectors attached to it, but something in the middle is holding fast to this box.
Anybody have a lot of experience removing these? I'm tempted by soldering the wires to the pins on the open side of the ignition harness's plug and avoid removing this box at all.
tedmond
Gold - Posts: 4,610
Posted: September 13, 2010 at 4:42 PM / IP Logged
im pretty sure the new vw have aitbags at  the knee bolster. careful when removing.
Ted
Compustar Expert
Platinum - Posts: 12,488
Posted: September 14, 2010 at 8:54 PM / IP Logged
If the 2010 is the same body style as the 06/07 then you do not need to remove the black box. You can grab all the ignition wires are the base of the black box connector. This is where I normally get mine.
