99 alero on avistart 4113
timo123451
Member - Posts: 49
Posted: September 23, 2010 at 9:29 PM / IP Logged
I will be installing an avistart 4113 remote start in our 99 alero. I have one wire that I'm not sure on it's connection. The wire is H 1/4  WHITE/ blue  (-) activation input. I'm not sure if I need to even hook this wire up on my vehicle, the instructions show it going to a momentary switch.  Any suggestions? Thanks
t&t tech
Platinum - Posts: 2,622
Posted: September 24, 2010 at 6:42 AM / IP Logged
Nope, don't need it, however you can use it if you want push to start, so to speak, install a momentary button with one side to ground and the other side to the WHITE/ blue wire and when you press it for the programmed number of activation pulses the vehicle will start, kinda comes in handy sometimes like in the instance family goes in the vehicle to wait for you whilst your'e still dressing, they could just push the button start up and take in the a/c to keep cool until you come in the car and take over with the keys and drive off.
timo123451
Member - Posts: 49
Posted: September 24, 2010 at 7:07 AM / IP Logged
Thanks for the info!
t&t tech
Posted: September 24, 2010 at 1:55 PM / IP Logged
No problem. Welcome to the fourms by the way.
xxunknownxx
Member - Posts: 43
Posted: September 24, 2010 at 6:47 PM / IP Logged
WoW!!! Ive never thought of doing that. Now thats an awesome idea.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
