04 ford explorer remote start wire
soberano22
Posted: September 30, 2010 at 12:36 AM / IP Logged
I'm trying to install a C3-RS-915LCD remote start on my 04 explorer with factory alarm
i can match some wires from the remote start to the explorer but some idk were they go or if they don't go at all, please let me know if i can forget about some wire and were the other ones go
Ground output while running- is the ground for a bypass
second starter output- N/A
2-step unlock/factory disarm/sensor by-pass - ?
Instant start and turn off input - FOR TESTING THE REMOTE START
dome light control output - NEED RELAY FOR THIS
Horn output(programmable) - SO IF I WANT TO USE THE FACTORY HORN
Channel 4 programmable output -NEED HELP IDK
Neutral safety switch input -IDK
Ground output when disarmed -IDK
Tachometer signal input -TO TACH WIRE
Channel 6 programmable output -IDK
Accessory 2 control output -IDK
Diesel wait to start input -N/A
Ignition 3 control output -N/A
Zone 3(-) negative dor pin trigger -IDK
WHATS MY DOOR TYPE
Channel 2(trunk) output -IDK
Zone 2 negative hood/trunk trigger -TO HOOD PIN
(+)brake switch shutdown input -TO BRAKE SWITCH
Zone 3(+) positive dor pin trigger -IDK DOOR TYPE
(-) negative hood pin safety shutdown -TO DOOR PIN
Ground output when armed -TO RELAY
Channel 5 programmable output -IDK
were to mount the senser???
can use the factory led on this?
pitoaudiovisual
Copper - Posts: 388
Posted: October 02, 2010 at 9:48 AM / IP Logged
ok here we go
Channel 4 and 6 are for extras like sliding doors or automatic trunk open etc not need for ur install
neutral safety switch has to see a ground for the remote starter to work usually connected to a toogle switch
Ground output when disarmed wont be used
Accessory 2 is if ur car has 2 acc wires that have to be connected for the remote starter to work
Zone 3 negative door pin is for ur doors which i believe are negative so u will connect this wire
Channel 2 is if u have an automatic open truck that u push the botton and it opens
 Zone 3 is if ur doors use a positive
negative hood pin goes to the hood so if ur hood is open the car will not remote start
The sensor i usually mount under the dash on a solid part of the car
The factory led will work if u connect the factory arm and disarm wires to the alarm
Confidence is the key to any project!!
soberano22
Posted: October 02, 2010 at 11:41 PM / IP Logged
this is great it helps alot, got some more question hope you can help
on the stage shock sensor it has
zone 1 warn away input???
zone4 ground trigger???
ground- to ground
12+volts- can i put all my +12volts on the same wire?
programmable output 2 steps unlock output???
thanks for the help
soberano22
Posted: October 03, 2010 at 10:17 AM / IP Logged
ground- to ground
thanks for the help
ok i know what to do with the shock sensor
but not the programmable output 2 steps unlock output
pitoaudiovisual
Copper - Posts: 388
Posted: October 04, 2010 at 1:26 PM / IP Logged
i just responded to ur private message
