dodge ram 2008
adamski
Member - Posts: 17
Posted: October 11, 2010 at 9:42 PM / IP Logged
Hello I am in the middle of installation on viper 5902
I'm looking for wiring diagram for 2008 dodge ram that will tell me where to find door triggers, thank you any help I will really appreciate
Aja.
Adam
Platinum - Posts: 13,726
Posted: October 11, 2010 at 10:47 PM / IP Logged
1500, 2500, or 3500?   2 dr. or 4 dr?
adamski
Member - Posts: 17
Posted: October 12, 2010 at 7:02 AM / IP Logged
it's 2008 dodge ram 4 door 1500 hemi
Adam
Platinum - Posts: 7,828
Posted: October 12, 2010 at 7:30 AM / IP Logged
This info from Bulldog Security:
THE LEFT FRONT DOOR IS PURPLE IN PIN 1. THE RIGHT FRONT DOOR IS PURPLE / WHITE IN PIN 4. THE LEFT REAR DOOR IS PURPLE / ORANGE OR PURPLE /GRAY IN PIN 2. THE Right REAR DOOR IS PURPLE / YELLOW OR TAN / YELLOW IN PIN 3. USE ALL
4 WIRES AND DIODE ISOLATE EACH WIRE FROM EACH OTHER AND THE INSTRUMENT CLUSTER.
This info from Audiovox:
 LF Latch    VIOLET  (-)                   IN HARNESS IN DRIVERS KICKPANEL
 RF Latch    VIOLET/WHITE  (-)     IN HARNESS IN PASSENGER KICKPANEL
 LR Latch    VIOLET/GRAY  (-)       IN HARNESS IN DRIVER KCIKPANEL
 RR Latch   VIOLET / YELLOW  (-)  IN HARNESS IN PASSENGER KICKPANEL
adamski
Member - Posts: 17
Posted: October 19, 2010 at 6:36 PM / IP Logged
viper 5902 Dodge ram 08 4 door installation
Hello I need some help, I got all wires done you can say, accept parking lights wire witch I run through 1120ohm resistor witch is giving me negative, do I need to use relay to switch the wire to positive, if I do what's the right way to wire the relay, if there is different easier way to go through??
thank you.
Adam
Posted: October 19, 2010 at 7:20 PM / IP Logged
This note from AudioVox : MUST ISOLATE FROM THE SWITCH WITH A RELAY DUE TO A REST RESISTANCE FORM THE SWITCH, USE A 1.1K OHM RESISTOR
Set your Viper Parking Light jumper to (+)
Use 30/40A SPDT relay
Viper H1/11 to Relay Pin 86
Relay Pin 85 to Chassis ground
Relay pin 87a to Light Switch side of cut WHITE/ Light Green wire
Relay Pin 87  thru 1.1 K Ohm resistor to chassis ground
Relay Pin 30 to car side of cut WHITE/ Light Green wire
adamski
Member - Posts: 17
Posted: October 26, 2010 at 8:47 PM / IP Logged
viper 5902, just finished installation. Thank you very much for all your help, does anyone of you know where I would be able to find defrost mirrors wire in 08 ram hemi 1500 4 door.
Thanks again.
Adam
