audi factory alarm disarm
geezer05
Posted: October 31, 2010 at 6:28 PM / IP Logged
hi,
i have installed a remote start in my 1999 audi A6. everything went well or so i thought until i tried to start it with the oem alarm on. this triggers the factory alarm. on the wiring i was given it said N/A to the disarm wires because it disarms with the unlock. however this is useless if you have to unlock the car every time you want to start it. so if anyone knows the wire i need or how to trace it that would be great, otherwise i guess ill just leave it unlocked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
chev104275
Gold - Posts: 1,436
Posted: October 31, 2010 at 7:07 PM / IP Logged
You could tie the fad wire to the unlock wire then set the system to relock after start. This way it would unlock and disarm the factory alarm then relock after it starts. I'm assuming your system has this feature as you didn't tell us the brand
Posted: October 31, 2010 at 7:43 PM / IP Logged
What Chev says is correct as usual, it's the only way, those bloody German cars have a (twisted) logic of their own. You can't even do that on an A4 after 02, you can effect lock, close factory alarm and deadlock but not unlock! You need a CANMAX 400 or similar.
geezer05
Posted: October 31, 2010 at 10:21 PM / IP Logged
hi,
its a viper 5901, im not sure if mine has the ability to lock after remote start, i cant see it on the programming sheet?
zerepdivad
Silver - Posts: 605
Posted: October 31, 2010 at 10:23 PM / IP Logged
disarm to unlock, and -starter out to lock. simple.
A DMM is a beautiful thing.
geezer05
Posted: November 01, 2010 at 12:23 AM / IP Logged
thanks, sweet and simple, i like.
zerepdivad
Silver - Posts: 605
Posted: November 01, 2010 at 7:01 PM / IP Logged
yup. obviously you'll want to diode isolate the neg starter.
Sunday, August 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
