2000 maxima remote start
razuuk004
Member - Posts: 23
Posted: November 02, 2010 at 5:42 AM / IP Logged
Hey guys, Okay the car is a 2000 Nissan Maxima and the equipment is a Viper 5701 security w/ R/S and a DEI 556uw immobilizer unit. I put the coaded key inside the 556u, I put the rf ring around the key cylinder of the car (but i didn,t disable the factory key reader in the cylinder), i connected the blue wire to the status wire (blue/white) of the alarm and cut the starter wire to connect them according to the wiring diagram. when I attempt to remote start the car i get a 7 chirmp signal from the alarm. Am I missing something? and what about the Programing?
Platinum - Posts: 7,827
Posted: November 02, 2010 at 6:56 AM / IP Logged
The 7 blinks means that you are still in Manual Transmission Mode.  Is this car an automatic?  If you don't have one, download the Viper 5701 Install Guide from the "Downloads" section.  There is a programming option that needs to be changed if your car is an Automatic. ( Menu 3, Menu Item 1, Option 2.  Here is a link with programming instructions :  https://www.the12volt.com/installbay/file.asp?ID=711 )   If it is a manual, then you didn't enter into "Reservation Mode".
The Viper unit is fairly complex and the Install Guide can clear up a lot of issues.
razuuk004
Member - Posts: 23
Posted: November 02, 2010 at 11:17 AM / IP Logged
Yes, The car is Automatic. Also a question about the rf ring on the DEI 556uw, should i locate the ring around the key cylinder and leave the factory transponder intact or cut the factory ring and wire into it like option 2 on the 556uw manual?
Posted: November 02, 2010 at 11:31 AM / IP Logged
Just securely mount the 556u antenna in  the correct location.  No need to do the Option 2 install.  The 556U will only broadcast the "key in the box" transponder code when the remote starter is active.
razuuk004
Member - Posts: 23
Posted: November 02, 2010 at 1:02 PM / IP Logged
...and the parking neutral safety cable should be grounded to chassis. There is also a cable labeled Turbo Start that is wired to a switch then grounded on the other end. Other than the Red, RED / Black, RED / White wires that go to 12volt Constant, the 2 that go to both sides of the starter cable (Ign side/ Motor side). What other wires do i absolutely need to hook up to make the R/S work?
Posted: November 02, 2010 at 3:17 PM / IP Logged
Well, lets see...  On the car side, there's
Ignition 1
Starter 1
Starter 2
Accessory 1
Accessory 2
Parking Light (+)  - could be considered optional
Brake (+)
Tach  -  could go Virtual Tach but...
Door Trigger(s)
All wires in the car should be verified with a DMM prior to making any connections.
Plus desirable optional items like Lock, UnLock, Trunk and Factory Alarm Disarm (if equipped)
On the Viper side, there's
All four +12v power wires
Chassis Ground
Parking Light Output
Door Trigger (-)
Neutral Safety Switch
Tach
Brake
Hood Pin
(-) Accessory ( to relay for ACC2 )
Status Output
Everything on the H3 except H3/8
The 556u with a spare key
Plus the above "desirable items"...
razuuk004
Member - Posts: 23
Posted: November 02, 2010 at 5:02 PM / IP Logged
.All wires of the h3 harnest are connected except pink/black. BLACK/ white (neutral switch) is grounded. Brake cable is hooked. Tach is not. Door trigger is up. When I try r/s, it gives me 1long red sigal and 8 chirps. (neutral switch) but wire is grounded.
Posted: November 02, 2010 at 5:42 PM / IP Logged
Eight chirps sounds like the Neutral Safety switch.  I would double check that wire and connection.
t&t tech
Platinum - Posts: 2,622
Posted: November 02, 2010 at 7:03 PM / IP Logged
Make sure you have the inline toggle switch plugged in and in the on position.
razuuk004
Member - Posts: 23
Posted: November 04, 2010 at 11:28 AM / IP Logged
Okay,Just to verify. The (-) Accessory ( to relay for ACC2 )
Status Output is the Blue wire of the Viper and it goes to the Blue wire of the 556u which gives a negative signal to the immobilizer box.
I don't think this car has Starter 2.
The brake wire should show me a (+) polarity when not pressed and switches to (-) polarity when pressed?
My Neutral safety switch is grounded at the same point as the Vipers Ground wire.
Tach. is not connected but this car is automatic and i dont think that it would stop the viper from even trying to crank over.
And All four +12V Power wires are the 3 fused from H3 harness and the main 12V+ from the alarm itself (also fused).
I don't Know if the toggle switch would make a difference but i tried it both ways.
...and still I get the same result. Red light with one long error sound from the remote followed by 7 clicks from the alarm.
I am stomped. I can only think that either the rf ring is not sending the frequency correctly to the Key Cylinder, it's not on the right location, or it's defective.
Am i missing something?. How can i check to reduce my conclutions and pinpoint the problem?
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
