viper 5301, 1999 subaru outback
wallyblackburn
Member - Posts: 8
Posted: November 24, 2010 at 1:03 PM / IP Logged
While waiting on my Viper 5301 to arrive, I decided to plan the connections as much as I could. I posted a PDF of the connections I intend to make and what I intend to leave unconnected. I marked in orange where I still have questions to answer.
Any comments/confirmations/criticisms on my Connection List
appreciated.
Thanks,
Wally
wallyblackburn
Member - Posts: 8
Posted: November 24, 2010 at 1:04 PM / IP Logged
1999 Subaru Legacy Outback, (broken) factory keyless entry, (non-working) factory alarm
Platinum - Posts: 7,828
Posted: November 24, 2010 at 2:08 PM / IP Logged
Possible issues:
1.) The (-)Unlock is White, not RED / White.
2.) FACTORY ALARM DISARM               GREEN/ LIGHT BLUE (-)                        IN DRIVERS KICK PANEL.
3.) The RED / Blue Parking Light wire is (+).  There is also a  PARKING LIGHTS ( - )              BLACK/ GREEN (-)             @ HEADLIGHT SWITCH.
As always, these wire listing guides are just that, a guide.  It is best to test and verify all connections.
Everything else looked good.  The only other step is programming the Viper to Tach Mode ( required to MTS mode )
and doing the Tach learn.  Depending on which Parking Light wire you use, set the Viper Parking Light jumper accordingly.
wallyblackburn
Member - Posts: 8
Posted: November 24, 2010 at 2:14 PM / IP Logged
Thanks. I haven't actually looked at any of the wiring yet - I will definitely confirm everything with multimeter as I go.
I was going to use the tach mode for engine monitoring, but I am really considering using automatic mode IF I am able to get a good neutral indication from ECM. Actually, I'll also look for parking brake switch (even though just a lightly-applied parking brake will still close it).
Thanks,
Wally
Posted: November 24, 2010 at 2:48 PM / IP Logged
Tach mode is the most reliable way to start the car.  I agree that dealing with  "Reservation Mode"  is a pain but having the car start in gear can have very serious consequences. viper 5301, 1999 subaru outback -- posted image.
Posted: November 24, 2010 at 5:16 PM / IP Logged
I'm pretty sure that there's a neutral safety terminal on the engine management. You could run the Viper as an auto. Test by trying to key start the car in gear.
wallyblackburn
Member - Posts: 8
Posted: November 28, 2010 at 2:51 PM / IP Logged
Viper 5301 says neutral safety not ground, but it is. Viper 5301 in 1999 Subaru Legacy Outback. Locks work fine. Remote start with 2-way remote emits error tone and flashes lights 8 times - Neutral Safety Switch not grounded or not on. I verified it is on and even connected it directly to ground - still 8 flashes.
Thanks,
Wally
smokeman1
Platinum - Posts: 1,589
Posted: November 28, 2010 at 2:58 PM / IP Logged
Remote start input- 5 pin connector, BLACK/ white must be to ground.  Do you have the toggle switch plugged in and in the ON position?
wallyblackburn
Member - Posts: 8
Posted: November 28, 2010 at 4:00 PM / IP Logged
Duh - I didn't have the toggle switch on...sigh. Thanks!
smokeman1
Posted: November 28, 2010 at 8:17 PM / IP Logged
Yeah, I know.    I did it myself once.     Didn't forget on my subsequent installs.
