97 wrangler tach
73corvettel48
Posted: December 18, 2010 at 6:04 PM / IP Logged
Can you hook up a tach connection at one of the two instrument cluster connections on this vehicle?  If so, do you know the wire color.  I hate to make a connection under the hood in such a salty environment.
Platinum - Posts: 13,726
Posted: December 19, 2010 at 7:41 AM / IP Logged
If there is a grey/white wire at the cluster, test it with a meter.
73corvettel48
Posted: December 19, 2010 at 9:15 AM / IP Logged
There was a gray and a gray and white, one turned out to be a turn signal and i forgot what the other was.  I got out a chilton manual wiring diagram and seen that the tach at dash is probably a data wire.  I just connected down at the coil anyway.
Thanks for the reply though
