2010 volkswagon eos wiring
jzzaremba83
Posted: December 22, 2010 at 11:36 AM / IP Logged
trying to install remote starter and keyless in 2010 volkswagon eos. Haing problems with lock and unlock and finding a tach wire. thanks
Platinum - Posts: 13,723
Posted: December 22, 2010 at 11:44 AM / IP Logged
One wire system, apply ground through a 250 ohm resistor to unlock.  Apply straight ground for lock.
2010 volkswagon eos wiring -- posted image. Power Unlock BROWN / GREEN (-) AT DRIVER DOOR MODULE IN DOOR 2010 volkswagon eos wiring -- posted image.
2010 volkswagon eos wiring -- posted image. PowerLock BROWN / GREEN (-) AT DRIVER DOOR MODULE IN DOOR
mustyk@att.net
Copper - Posts: 132
Posted: December 22, 2010 at 9:19 PM / IP Logged
FL-CAN module should have lock/unlock ability as well as provide tach signal
thetopinstaller
jzzaremba83
Posted: December 23, 2010 at 5:39 PM / IP Logged
put in fl-can piece and got door locks and trunk to work but not tach . Is there a special way to get tach to work. parking lights just flash as if tach wasnt programed
mustyk@att.net
Copper - Posts: 132
Posted: December 23, 2010 at 9:18 PM / IP Logged
Check the tach output from the FL-CAN with a high impedance test light (L.E.D. style) to see if its even working. You should see a flickering light that speeds up with acceleration.  I would clamp a Hi-impedence test light to constant power and test the FL-CAN output. If it works then theres something wrong with the tach Learn sequence.
thetopinstaller
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
