2002 saturn remote start
buzzstpoint
Member - Posts: 11
Posted: December 26, 2010 at 7:42 PM / IP Logged
Vehicle:
2002 Saturn L200
4 cylinder
Remote start: Bulldog RS1200
Bypass: Bulldog 791
I wired up the remote start, So far everything seems to work except the starting function.
The car will crank and start only to shut down 1-2 seconds later. I did notice the security light is on when this happens. I've doubled and tripled check the wiring. Trouble shooting says to clear the bypass and "relearn" the resistance. I have done this about 10 times already and still no luck.
I'm wondering if it has to do with the Keysence. According to the instrucions I should add a diode to the (-) out when running on the remote start. But then the Bypass says I should use the same wire.
I put the bypass wire before the diode. should this be after the diode?
Any other ideas why the car would shut down right away when using the remote start is activated?
blanx218
Silver - Posts: 654
Posted: December 26, 2010 at 8:34 PM / IP Logged
did 2 of these cars this week and did not have any luck with any bypass. i had to go old fashioned and use a relay and resistor
buzzstpoint
Member - Posts: 11
Posted: December 26, 2010 at 9:23 PM / IP Logged
Do you have a schematic of the "resistor and relay" version?
Platinum - Posts: 7,828
Posted: December 26, 2010 at 9:30 PM / IP Logged
Passlok2 bypass from Audiovox :  http://documents.audiovox.com/700054.pdf
zerepdivad
Silver - Posts: 605
Posted: December 26, 2010 at 9:40 PM / IP Logged
yup. that's the only way i do saturns. they often have oddball resistances apparently i guess is the issue.
A DMM is a beautiful thing.
buzzstpoint
Member - Posts: 11
Posted: December 27, 2010 at 10:52 AM / IP Logged
What type of relays are these?
SPDT? Amperage?
ayalja123
Copper - Posts: 64
Posted: December 27, 2010 at 1:13 PM / IP Logged
hey did you try using a pljk? i know that on xpresskit.com the pljk does not come up for this vehicle but i think it might work
blanx218
Silver - Posts: 654
Posted: December 27, 2010 at 1:24 PM / IP Logged
i thought the same thing but the pljx does NOT work. it will program (or appear to program) fine but as soon as you try the r/s it locks up the passlock
ayalja123
Copper - Posts: 64
Posted: December 27, 2010 at 1:43 PM / IP Logged
ok, good to know, thanks. I've done saturns but not this one
buzzstpoint
Member - Posts: 11
Posted: January 02, 2011 at 5:46 PM / IP Logged
Here's where I'm at.
I've wired up the Passlock according to the "audiovox" bypass instructions.
I now have a couple of issues.
When using the key, The security light will be lit but will start and run.
If I run the remote start, push on the brake the engine will shut down. After this, I can't start the engine with the key. I have to start the engine with the remote then use the key. Only after I do this will I be able to use the key.
Lastly, when I hook bypass in, the airbag light is on.
Any ideas on where to go from here?
