clifford 650 c/w intellistart new fob
i-vtec
Member - Posts: 23
Posted: January 24, 2011 at 6:49 AM / IP Logged
Hi, I have bought a damaged Honda civic type R 2002, and the owner had lost the key. and alarm fob.
I have removed the complete Alarm system.
Its a Clifford concept 650 with Intellistart 4.
How can i get a replacement new fob (programmed), along with a new Valet code.
Appreciated If some one can help me out.
Posted: January 24, 2011 at 8:33 AM / IP Logged
Armour Auto or a local dealer, you have to know if it's a Mk l or Mk ll 650.
The Mk ll will have two multi pin white connector blocks, also if you intend using it again order the new looms, plus LED and Valet switch looms. Did you remove the dual-zone prox and its lead and the antenna and its lead it won't even work without the antenna, also unless you have a Wizz software or know the valet pin code don't bother.
i-vtec
Member - Posts: 23
Posted: January 24, 2011 at 9:02 AM / IP Logged
Its Mk 1, and yes i have removed all wiring loom,sensors , antenna etc etc.
I do have the Wizard software but i couldn't use the software on my lap top on my other car last time.
Would the wizard work on vista?
Would the alarm unit need to be wired on to car in order for ne fob to be programmed.
Previous owner said, he never had no code, but he does have the booklet,would their be any info in the booklet at all.
Posted: January 24, 2011 at 10:06 AM / IP Logged
If you have the booklet the code number is on the back.
You can set it up on the bench, 5amp and 20amp power, one of the grounds, ignition input, siren, LED and aerial all need to be connected.
Your computer needs to have a serial port and pref Win 98 SE.
i-vtec
Member - Posts: 23
Posted: January 24, 2011 at 10:09 AM / IP Logged
Ok, so If its all set up like you said on a bench, and If i have the valet code, can i not programme a new fob via the programming feature?.
And thank you for your kind support.
Posted: January 24, 2011 at 10:32 AM / IP Logged
Yes. Done it many, many times.
Posted: January 24, 2011 at 10:34 AM / IP Logged
Yes, if you have the Valet pin code you don't need a computer, just go into user programming, erase the remotes and add the new.
