need odyssey 04 wire diagram
thang25
Member - Posts: 11
Posted: February 04, 2011 at 8:44 PM / IP Logged
Hi,
I am looking for a Odyssey 04 Ex-L wire diagram for remote start and 2 slides door but can't find it. I will wire it with Viper 5701 remote start. If anyone have a wire diagram please share with me. I will appreciate it.
Thanks,
Thang
monty_77
Copper - Posts: 491
Posted: February 05, 2011 at 2:07 AM / IP Logged
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
MODEL       YEAR(S)
ODYSSEY       2004 -
KEY       T-HARNESS       IMMOBILIZER
N/A       N/A       HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY
PART       COLOR       LOCATION
12 VOLT CONSTANT       WHITE (+)       IGNITION SWITCH HARNESS
STARTER       BLACK/ WHITE (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A
IGNITION 1       BLACK / YELLOW (+)       IGNITION SWITCH HARNESS
IGNITION 2       N/A
IGNITION 3       N/A
ACCESSORY /HEATER BLOWER 1       YELLOW (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       WHITE/ BLACK (+)       IGNITION SWITCH HARNESS
KEYSENSE       N/A
PARKING LIGHTS ( - )       N/A
PARKING LIGHTS ( + )       RED / BLACK (+)       @ 10 PIN PLUG DRIVER SIDE FUSEBOX
POWER LOCK       BLACK/ BLUE (TYPE B) See NOTE *1       @ PASSENGER SIDE FUSEBOX, See NOTE *2
POWER UNLOCK       ORANGE (TYPE B) See NOTE *1       @ PASSENGER SIDE FUSEBOX, See NOTE *2
DOOR TRIGGER       BLACK/ WHITE (-), Requires Part #775 Relay       @ INTERIOR LIGHT SWITCH
DOMELIGHT SUPERVISION       LIGHT GREEN (-), Requires Part #775 Relay       @ INTERIOR LIGHT SWITCH
TRUNK RELEASE       N/A
SLIDING POWER DOOR       N/A
HORN       LIGHT GREEN/ BLUE (-)       @ STEERING COLUMN HARNESS
TACH       BLUE       @ 2-PIN PLUG ABOVE BRAKE MASTER CYLINDER
WAIT TO START LIGHT       N/A
BRAKE       WHITE/ BLACK (+)       @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       See NOTE * 3
ANTI-THEFT       TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY       TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 these wires can ONLY be metered or tested buy turning the key in the PASSENGER DOOR KEY CYLINDER. NOTE *2 these wires are found in a 20-pin plug on the LX models and on the EX models the wires are in a 3-pin plug. NOTE *3 the DISARM wire on the EX is a BLACK/ RED to BLUE (-) in the DRIVERS DOOR Module in the drivers door.
thang25
Member - Posts: 11
Posted: February 09, 2011 at 11:21 PM / IP Logged
Thank you monty_77
Right now I am planning the wiring connection and I don't know where to connect some of wires from remote to... I hope someone could help me point out where are these connection connect to. This is my 1st time install/mod car electrical.
H1/4 wht/bro flex parking light relay 87A
H1/7 blue trunk (-) instant trigger input
H1/8 green door (-) input
H1/10 wht/ble remote start activation (-) input
H1/12 orange ground when armed (-) 500mA output
RS in blu/wht 2nd remote start status (-) output
H2/2 light GREEN/ wht oem arm (-) 200mA output
H2/6 light blue 2nd unlock (-) 200mA output
H2/8 bro/blk (-) 200mA horn honk output connect to horn?
H3/2 RED / wht fused 30A (contact 87 of rS flex relay) connect to #775 relay?
H3/3 orange accessory output connect to yellow(+) and/or wht/blk (+)??
H3/4 violet starter output connect to blk/wht (+)?
H3/5 green starter input (does it connect to wht (+)12V constant?)
H3/6 red 12V(+) constant connect to wht(+)??
H3/9 RED / blk for accessory and starter relays?
monty_77
Copper - Posts: 491
Posted: February 09, 2011 at 11:56 PM / IP Logged
You will not need ether of these wire for the remote starter
will not us this, it used to start the remote start from something like door locks pressed three times.
hook to something you want to turn on when doors are locked (like extra sensors)
thang25 wrote:
RS in blu/wht 2nd remote start status (-)output
This will be used on the Status wire of bypass also known as GWR (Ground While Running)
Will not use this wire
you will only use this if you want to set up drivers door priority and if you don't want to don't worry about it
you do not need to hook it up but it will help with programming
you will want to hook this to a 12 volt source. white wire
this will power the pink/white wire.
only hook it to one of the two you can use the programable pink/white for the other one
yes hook it to the blk/wht in the ignition harness
no this wire can be hooked to the starter wire for anti-grind(starter kill) feature
if you want to hook this up you will have to cut the starter BLACK/ white wire and hook this one to key side of wire and the violet starter output to the vehicle side of the wire.
yes will get hooked to the white 12 volt
this will get hooked to the white 12 volt also
please note that you can hook all the 12 volts to battery too
thang25
Member - Posts: 11
Posted: February 15, 2011 at 5:57 PM / IP Logged
Thank for your information...
I tried find a blue wire for tachometer above the brake paddle and I can't find it. Does it locate any other location?
Thanks.
monty_77
Copper - Posts: 491
Posted: February 15, 2011 at 6:04 PM / IP Logged
in a lt blue connector in the drivers kick panel (blue wire)
it might be blue with silver on it not a strip
thang25
Member - Posts: 11
Posted: February 15, 2011 at 6:17 PM / IP Logged
Never mind I found it. How do it find blue tachometer inside the van?
thang25
Member - Posts: 11
Posted: February 15, 2011 at 7:04 PM / IP Logged
I tried to find a factory disarm alarm wire with "NOTE *3 the DISARM wire on the EX is a BLACK/ RED to BLUE (-) in the DRIVERS DOOR Module in the drivers door"
Could someone tell me what is BLACK/ red to blue (-) mean??? I found blue/red wire but no BLACK/ red or blue in a driver door box.
buddholly
Copper - Posts: 244
Posted: February 16, 2011 at 6:01 PM / IP Logged
It just means that wire changes from BLACK/ red to blue after a connector somewhere in the vehicle. Basically that wire is located on the door lock switch inside of the door, I would also check for it comming out of the door harness, probably a thin little wire.
thang25
Member - Posts: 11
Posted: February 16, 2011 at 6:28 PM / IP Logged
Can someone help please...
How do I change the setting from manual transmission to automatic ??
Thanks again.
