prostart and montana 2002
neon150hp
Posted: February 26, 2011 at 4:20 PM / IP Logged
Hi,I've just installed a prostart ct-3170 and a bypass kit from xpresskit model DLPKGM and the car start fine and the only thing problem I got is the passlock light stays on with the key in the ON position,if I press stop button on the remote,the light goes of for 5 sec. and come back.
So,what am I missing,there nothing in the user manual about this problem,thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: February 27, 2011 at 7:58 AM / IP Logged
Does it illuminate when you start the van with a key?
I do not see a way to reset the bypass in the DLPKGM install manual, have you tried going through the programming sequence again?
Where did you get your ground, make sure it is to a clean, paint and primer free section of the kick panel, not to an under dash piece of metal.
neon150hp
Posted: February 27, 2011 at 4:17 PM / IP Logged
When I start the van,everything's fine,i'll try to do re-program the DLPKGM but i'm pretty sure it's not the problem and I will try another place for a ground.
