2004 Maxima starter wiring
Telemotix
Posted: April 24, 2003 at 8:29 AM / IP Logged
About to install a starter interrupt and remote door unlock. Anybody gotten into the 2004 Maxima yet? Looking for wiring colors and locations. Thanks!
draasch
Gold - Posts: 2,172
Posted: April 24, 2003 at 8:35 PM / IP Logged
here is 2002
double check your wires..............
Constant 12 volts RED (2) IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light PURPLE (-) 4 PIN BLACK CONN. IN DR. KICK PANEL *
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock L BLUE DRIVER KICK #203
Power Unlock WHITE PANEL ** #202
* PURPLE (-) Wire Also Located At Headlight Switch. WHITE (-) Wire At Courtesy Light Can Also Be Used But Will Not Trigger Alarm If Dome Lamp Override Switch Is Turned On. ** Without OEM Keyless Entry See Note #203. With OEM Keyless See Note #202. #203- See Reversal Rest At Ground Door Lock Diagram. #202- See Positive Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Telemotix
Posted: April 25, 2003 at 12:27 PM / IP Logged
Hey thanks. According to Wire Magic, I'll need to run a new wire to the door switch for the unlock/lock function. I'm new to this stuff but this does sound weird. Anything in the door should be duplicated in the kick panel wiring? I'll dig into this again next week and post the results. Thanks again for the info.
JWorm
Platinum - Posts: 2,208
Posted: April 25, 2003 at 10:05 PM / IP Logged
"Anything in the door should be duplicated in the kick panel wiring?"
Welcome to the world of multiplexed doorlocks and windows.
