door trigger
old goat 67
Posted: May 28, 2011 at 9:57 AM / IP Logged
Help guys,
I am wiring an Alarm/ Remote Entry unit in my 67 GTO and I am having much difficulties with trying to figure out the deffinitions of each.
My old car only has a lead with 12V on it trough the coustesy lights looking for a ground when the door is opened, to turn on the lights.
Would you hook up the Neg Door Trigger lead to this, or do I need some extra stuff like another switch?
Charles
Platinum - Posts: 13,726
Posted: May 28, 2011 at 10:47 AM / IP Logged
Find the pin switch in the front of the door jamb, there should be a single wire connected to the back of it.  It may be a white wire.  Connect it to that wire.
old goat 67
Posted: May 28, 2011 at 11:01 AM / IP Logged
It's a white wire with 12V coming to the door switch from the courtesy lights. It goes grounded when the door is opened and I have tried hooking it to the door - wire, but no help.
I am at my wits end and have been in electronics all my life.
Charles
Posted: May 28, 2011 at 11:33 AM / IP Logged
That's the correct one. Assuming a DEI alarm it would go to the green wire.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
