99 jeep cherokee 2 way alarm
elmigraman
Posted: August 05, 2011 at 8:24 PM / IP Logged
Good evening everyone,
I just purchased a two way Performance Teknique 2 way car alarm ICBM-7071, and I am about to attempt to install it. I am somehow familiar with electronics and this forum has provided a wealth of knowledge over these years. I searched for a tutorial to install this alarm, but I did not have any luck. Can anyone provide a step by step as to how install the alarm? For instance, I do know how to take apart the ignition switch and test wires for voltage. From there, I am lost since I do not know where is the 99 jeep cherokee factory door module, or if the door locks are negative or positive  triggered (how do i test for this?), vacuum type, reverse polarity, etc? I know that I am asking for too much, and that this alarm is very cheap, but is all I could afford now. All the help is greatly appreciated.
I attempted to install a starter kill switch, but after reading here, I am not sure if I need a relay with a diode or not. I was trying to put the switch inline with the brown small gauge wire that goes to the starter (I believe it comes from the ignition). But I did not know if a relay is needed. Please help.
I posted a link to the diagrams, and that is all it came with the alarm. As you can see it is pretty generic and useless for the noobs like me.
https://i1208.photobucket.com/albums/cc365/beautifulbella2011/Car%20Alarm/scan0003.jpg
[IMG]https://i1208.photobucket.com/albums/cc365/beautifulbella2011/Car%20Alarm/scan0001.jpg[/IMG]
https://i1208.photobucket.com/albums/cc365/beautifulbella2011/Car%20Alarm/scan0004.jpg
[IMG]https://i1208.photobucket.com/albums/cc365/beautifulbella2011/Car%20Alarm/scan0004.jpg[/IMG]
[IMG]https://i1208.photobucket.com/albums/cc365/beautifulbella2011/Car%20Alarm/scan0003.jpg[/IMG]
Very respectully,
Joe
elmigraman
Posted: August 16, 2011 at 10:40 AM / IP Logged
Please...Can someone help me? I would like to do the installation on my own. At least can someone provide enough information to get started?
Thank you,
Joe
casofwaco
Member - Posts: 26
Posted: August 16, 2011 at 11:45 AM / IP Logged
99 jeep cherokee 2 way alarm -- posted image. Battery PINK/BLACK
99 jeep cherokee 2 way alarm -- posted image. Battery PINK/BLACK (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Ignition 1 BLUE (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Ignition 2 BLACK/ ORANGE (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Accessory 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Anti-Theft Type DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
99 jeep cherokee 2 way alarm -- posted image. Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
99 jeep cherokee 2 way alarm -- posted image. Key Sense PINK/LIGHT BLUE (-) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Neutral Safety YELLOW (+) IGNITION SWITCH HARNESS
99 jeep cherokee 2 way alarm -- posted image. Tachometer GRAY (-) AT IGNITION COIL
99 jeep cherokee 2 way alarm -- posted image. Parking Lights BLACK / YELLOW (+) AT VEHICLE LIGHT SWITCH
99 jeep cherokee 2 way alarm -- posted image. Brake Lights WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
99 jeep cherokee 2 way alarm -- posted image. Reverse Lights BROWN / LIGHT GREEN (+) IN HARNESS IN DRIVERS DOOR SILL
BAD Boy Emergency Vehicle Lighting
casofwaco
Member - Posts: 26
Posted: August 16, 2011 at 11:50 AM / IP Logged
All Door Trigger YELLOW (-) IN HARNESS IN DRIVERS KICKPANEL
Trunk Trigger TAN/BLACK (-) AT LIGHT IN TRUNK
Power Unlock PINK/VIOLET (-) IN HARNESS IN DRIVERS KICKPANEL
PowerLock ORANGE / VIOLET (-) IN HARNESS IN DRIVERS KICKPANEL
Trnk Release PINK/BLACK (+)
I hope this helps some
elmigraman
Posted: August 16, 2011 at 10:45 PM / IP Logged
Thanks a lot. I will start working tomorrow on this project. I am kind of nervous because it will be my first alarm install.
Thanks for the help!
