viper 5301, gmdlbp, 03 silverado.
jrock1679
Posted: September 30, 2011 at 9:03 PM / IP Logged
Hi all, I am having an issue with the keyless entry side of this install. I have the remote start working, but the door lock/unlock is not working. When I press either button on the remote, the parking lights flash, horn chirps, and the viper module clicks. The doors do not lock or unlock. I have the blue and green wires from the GMDLBP connected to the corresponding wires in the 3 pin connector of the Viper module. This is my first install of this type and any suggestions would be greatly appreciated. Thanks in advance.
jrock1679
Posted: September 30, 2011 at 9:04 PM / IP Logged
BTW, my factory fob still works at locking and unlocking. I'm just having the issue with the viper remotes.
Platinum - Posts: 7,827
Posted: September 30, 2011 at 10:01 PM / IP Logged
Did you set the GMDLBP to Platform 4?  The factory default is Platform 1.  See the lower part of Page 3 ( right side ) of the install guide for instructions.
jrock1679
Posted: September 30, 2011 at 10:41 PM / IP Logged
I just tried that with the same results. No luck. I reset the module and reprogrammed to platform 4. I still get all the same signals, just no lock or unlock.
Mark Mizenko
Copper - Posts: 460
Posted: October 03, 2011 at 2:15 PM / IP Logged
What happens if you pulse the lock and unlock wires right to ground in the vehicle?  Does it work then?
Thursday, January 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
