valet 552t
gaetzie
Posted: November 08, 2011 at 10:12 PM / IP Logged
I recently bought a 99 chevy tahoe from private guy didnt know it had the 552t in it and also didnt get any remotes. I would just like to get rid of it and im curious about what is involved can i just remove it or did it replace any of the factory harnesses? Just want your input im confident with electrical just dont know much about this valet
gaetzie
Posted: November 08, 2011 at 10:38 PM / IP Logged
model your valet 552t
Twelvoltz
Platinum - Posts: 2,384
Posted: November 09, 2011 at 7:16 PM / IP Logged
Doesn't it get cold in Wisconsin? Why not pick up a remote for $25 and use it? Remote start for $25 is cheap!
If you are not interested in using the system and want to remove it, it is a straight forward process if you are familiar with wiring. There should have been no factory harnesses replaced, simply tapped into. Take it one wire at a time, and insulate any connections you remove. Reconnect any wires that may have been cut (starter kill, etc).
Monday, November 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
