Giordon G686sp Remote Start, 94 Honda Civic
cayovolt
Posted: November 14, 2011 at 6:40 PM / IP Logged Link to Post Post Reply Quote cayovolt
I have a Giordon G686SP alarm with remote start.   I have it installed on a 94 honda civic. Cannot activate remote start.   When the car is started, I put car in neutral and parkbrake up then press the remote start button and unlock then remove the key.... the car stays on, but when i close the door, the car does not shutdown.
Lock and unlock work. door trigger is -ve and it works too cause when you open the door its chirps twice.   Any ideas on what is wrong
1994 Honda Civic
12pin Connector     Honda Side
P01 Black to Ground
P02 Not used
P03 Blue -ve trigger       to     Light green / red (-)
P04 Not used
P05 Brown turning lights   to     RED / Black
P06 purple to     Tach Wire
P07 positive 12V           to     white wire   ignition harness
P08 pedal brakes           to     GREEN / WHITE brake switch
P09 ON white              to     BLACK / YELLOW ignition harness
P10 Brown turning lights   to     RED / Black
P11 Pink horn output       to     hornwire the comes with alarm
P12 Not used
4Pin with Relays
Blue   Starter    to   starter wire Black\White
White ON        to   BLACK / YELLOW ignition harness
Green ACC        to   yellow       ignition harness
Yellow Not used
RED / Black Not used.
RED 12V           to   white wire   ignition harness
As I said.... alarms works fine... cannot enable remote start... this is a manual transmission.
The wise man said it could not be done and it was always the fool that did it
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
