xk01 with avital 4103
nojooms
Member - Posts: 6
Posted: November 18, 2011 at 10:57 PM / IP Logged
I have xpresskit xk01 GMDL5X firmware and avital 4103 remote starter 0n 2006 chevy malibu.Trying to use D2D port which wires to connect beside d2d from 9 pin connector?.Is the data wire on the obd2 #1 green or #2 purple?.
the xk01 manual not too much help,thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: November 19, 2011 at 2:28 PM / IP Logged
Depending on the version of the 4103 you have, it may not work with D2D. There was/is a issue with the Avital units in D2D mode...it doesn't work right. I would strongly suggest W2W on that one.
nojooms
Member - Posts: 6
Posted: November 19, 2011 at 11:22 PM / IP Logged
its avistart 4103
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
