2005 chevy cobalt starter wire
juanr1045
Posted: January 03, 2012 at 11:38 AM / IP Logged Link to Post Post Reply Quote juanr1045
Does any one know what wire is the starter wire on a 2005 Chevy cobalt
i installed a alarm and cant find the wire to cut for the starter i am trying to cut off the starter when the alarm is armed
Platinum - Posts: 13,726
Posted: January 03, 2012 at 4:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
I thought that vehicle had data start commands. After looking at Audiovox info for that vehicle, I think it does.
     Battery          RED / BLACK          (+)          BCM - PIN D1 - IN C3 PLUG
     Ignition 1          YELLOW          (+)          IGNITION HARNESS
     Accessory 1          BROWN          (+)          IGNITION HARNESS
     Starter 1          ******
     Anti-Theft Type          PASSLOCK 2
Posted: January 03, 2012 at 4:25 PM / IP Logged Link to Post Post Reply Quote howie ll
Don't! Mr. I is correct. What's a Chevrolet?
jseibold
Copper - Posts: 98
Posted: January 04, 2012 at 10:38 AM / IP Logged Link to Post Post Reply Quote jseibold
If all you are doing is starter kill, here is the wire you need to interrupt:
Purple wire (for starter kill only)-located at starter or at underhood fuse box, black 68 pin plug, pin B10.  I would suggest having your starter kill relay installed inside the car and then extending the appropriate gauge wires out to the purple wire under the hood.
juanr1045
Posted: January 04, 2012 at 5:49 PM / IP Logged Link to Post Post Reply Quote juanr1045
do you know if it is  +(pos) or -(neg)
Posted: January 04, 2012 at 6:09 PM / IP Logged Link to Post Post Reply Quote howie ll
Try testing. Actually it doesn't matter and I'll let someone else explain why.
sparkie
Platinum - Posts: 2,061
Posted: January 04, 2012 at 6:22 PM / IP Logged Link to Post Post Reply Quote sparkie
The purple starter wire is a (+) circuit. it doesn't matter as the relay you use to open the starter wire doesn't use it for powering the relay coil. The relay coil should be wired as #86 to 12 volts + ignition and the terminal #85 to the starter kill output of the alarm. Cut the starter wire and connect the ends to terminals # 87a and #30.
sparky
juanr1045
Posted: January 04, 2012 at 7:49 PM / IP Logged Link to Post Post Reply Quote juanr1045
Posted: January 05, 2012 at 2:20 AM / IP Logged Link to Post Post Reply Quote howie ll
Thanks Sparkie, it was 00:30am UK time and I couldn't be bothered to explain.
Posted: January 05, 2012 at 2:59 AM / IP Logged Link to Post Post Reply Quote howie ll
On the 2011, and unless there's a vehicle body change it should be the same, transmission control module adjacent to air filter (next to or under), black 49 pin plug, pin 41 YELLOW.
