2006 chevy hhr remote start
lucasoil4u
Copper - Posts: 317
Posted: January 10, 2012 at 11:23 AM / IP Logged
Putting in a Remote start on a 2006 HHR Wondering if anyone has a wiring diagram and if anyone knows which wire the bcm data line is at the bcm for the bypass. dlpkgm. Thanks
offroadzj
Gold - Posts: 2,043
Posted: January 10, 2012 at 12:10 PM / IP Logged
Wire Diagram
As for the bypass, you'd be better off going with just the DLPK. It will control more than the DLPKGM (according to xpresskit.com) and will make the install a ton easier. The mux circuit can be a royal PITA to wire up manually. The DLPK will take care of the mux circuit, the immobilizer, locks, etc all through data. The DLPKGM will ONLY control the locks... so you will have to get an immobilizer bypass as well.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
lucasoil4u
Copper - Posts: 317
Posted: January 16, 2012 at 8:01 AM / IP Logged
what wire is the bcm data wire is what i am trying to figure out? I will be doing this remote starter next week. Thanks
Ryan
Platinum - Posts: 7,827
Posted: January 16, 2012 at 8:40 AM / IP Logged
The Data wire at the BCM is in connector C2 ( top plug of BCM ).  It is a Tan/White wire at Pin 12.
As Kenny pointed out, the DLPKGM will not do the transponder bypass function, only the door locks.
lucasoil4u
Copper - Posts: 317
Posted: January 17, 2012 at 9:04 AM / IP Logged
I am using the dlpk. Thanks a bunch guys
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
