python 323 on a 1996 ex
sonicgroovesi
Member - Posts: 11
Posted: January 13, 2012 at 9:11 PM / IP Logged
I have been searching on tips about installing this alarm I came across a post of a member that goes by superden. Hes installing his 323 in an 2004 HONDA CRV and the wiring schematics are the same as my 1996 civic. Now superden put a link up to the schematic of the way he was hooking up his i was wondering if someone could double check this link and let me know if its right. Especially the part about the door locks any help would be appreciated considering this is my first alarm install in like 10 years and a lot has changed since then. All my old friends have talked me up to my wife about how good i was when it came to tricking out cars (mainly in the performance dept) and im trying not to disappoint her or make her think my friends exaggerated a bit to make me look good to her before we married. Heres a link to the schematic pdf: in question. http://www.slideshare.net/superden001/excel-worksheet-9691324
and again thanks a head of time
sonicgroovesi
Member - Posts: 11
Posted: January 13, 2012 at 11:08 PM / IP Logged
hers his schematicts typed out in case anybody found it hard to read the link
PYTHON 323 ON 2004 HONDA CR-V
H-1:MAIN HARNESS
ALARM WIRE COLOR / CAR WIRE COLOR
1     (-) 200mA TRUNK RELEASE OUTPUT     RED / WHITE      BLACK / YELLOW (-)
2     (+) 12VDC CONSTANT INPUT      REDWHITE
3     (+) SIREN OUTPUT             BROWNSiren( +) wire
4        PARKING LIGHT ISOLATION
      WIRE-PIN 87a OF ONBOARD RELAY     WHITE/ BROWN      X
5     (-)CHASSIS GROUND              BLACKGround to Chassis
6     (+)DOOR TRIGGER INPUT             VIOLET        X
7     (-)TRUNK PIN/INSTANT TRIGGER
     INPUT (NC or NO)      BLUEGREEN / WHITE (-)
8     (-)DOOR TRIGGER     DR.:GREEN(-)DIODE Isolate
     INPUT (NC or NO)     GREENPAS.&REAR:GREEN/ RED(-)
9     FLEX RELAY OUTPUT             BLACK/ WHITE      X
10     (-) 200mA AUX1 OUTPUT             WHITE/ BLUE      X
11     PARKING LIGHT OUTPUT             WHITERED / YELLOW (+)
12     (-) 500mA GROUND WHEN
    ARMED OUTPUT      ORANGEGROUND(-)
H-2:DOOR LOCK HARNESS
1     UNLOCK #87 NORMALLY OPEN(INPUT) VIOLETGROUND (-)
2     UNLOCK #30 COMMON (OUTPUT)      BLUE/BLACK      WHITE/ GREEN
3     UNLOCK #87a NORMALLY CLOSED     BROWN / BLACK      X
4     LOCK #87 NORMALLY OPEN (INPUT)     VIOLET/BLACK      GROUND (-)
5     LOCK #30 COMMON (OUTPUT)     GREEN/ BLACK      WHITE/ BLUE
6     LOCK #87a NORMALLY CLOSED     WHITE/ BLACK      X
7     FLEX RELAY #87 NORMALLY OPEN     WHITE/ VIOLET      X
8     FLEX RELAY #87a NORMALLY CLOSED     WHITE/ BROWN      X
H-1:MAIN HARNESS
8     FLEX RELAY #87a NORMALLY CLOSED     WHITE/ BROWN      x
STARTER KILL HARNESS
"BLACK / WHITE wire, located under dash at FUSE / RELAY BOX Starter "
Wire Must Be Accessed After Fuse Block To Prevent Check Engine Light.
Cut BLACK/ WHITE wire & connect as directed.
1     STARTER-COMMON (KEY SIDE)          GREEN / WHITE   KEY SIDE BLACK/ WHITE
2     STARTER-NORMALLY OPEN(MOTOR SIDE)    GREEN        MOTOR SIDE BLACK/ WHITE
3     STARTER-NORMALLY CLOSED(MOTOR SIDE) GREEN/ BLACK   X
yesk13
Posted: January 14, 2012 at 3:49 PM / IP Logged
I also have the Python 323 hooked everything up, but got no respond from the module. the module did receive power to it and the valet/command center does have 5v but no LED light from it. My next try is to disconnect everything and connect the H1/2 and H1/5 to battery with the command switch to see if i get anything. if not i'll have to return it.
Posted: January 14, 2012 at 4:48 PM / IP Logged
First post, you have everything correct but obviously don't assume, test.
Starter cut,use GREEN/ black not green, it's inherently safer.
Second poster, recheck your wiring. These units almost never go wrong.
sonicgroovesi
Member - Posts: 11
Posted: January 14, 2012 at 5:37 PM / IP Logged
thanks for your response my wife gets to bring the car home on the26 guess ill be going ahead with the install wanted to get as much info on this installed before the car comes home don't want to give any one a chance to steal the car a civic was just stolen right over here a couple of weeks ago.i bet you'll see me on here a lot more   thanks.
sonicgroovesi
Member - Posts: 11
Posted: January 14, 2012 at 5:56 PM / IP Logged
Hey Howie iv'e got one ? that bugs me still on the H2 harness can you please explain to me why the H2/2 2 UNLOCK #30 COMMON (OUTPUT)      BLUE/BLACK wire goes to the cars WHITE/ GREEN power lock wire i kind of figured the alarms unlock wire would go to the cars unlock wire?i just find that strange but with all i don't know about alarms im extremly curious.plus if it isnt to much trouble how do you hook up the dome light security in case the wife would like that hooked up also thanks
Posted: January 14, 2012 at 6:16 PM / IP Logged
Just read my signature line!
yesk13
Posted: January 14, 2012 at 6:42 PM / IP Logged
i'll explain the WHITE/ green to unlock 30 common once i get home, i'll show you the wire diagram. i could even youtube it.
sonicgroovesi
Member - Posts: 11
Posted: January 14, 2012 at 7:06 PM / IP Logged
killer always trying to learn something new
yesk13
Posted: January 14, 2012 at 9:21 PM / IP Logged
sorry, have to wait till next day or monday. i have to double check the wire color of my H2 to door lock first.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
