negative when running
scottyt84
Member - Posts: 8
Posted: January 21, 2012 at 12:47 PM / IP Logged
I have an Omega Excalibur AL-2000-E with the IB-F3 and connot figure out where to hook up the "negative when running" wire from the IB-F3. If it helps it is on a 2006 Mazda5. Thanks guys!!
jstruckman
Copper - Posts: 465
Posted: January 21, 2012 at 1:12 PM / IP Logged
the AL2000-E will have a ground while running output that goes to the ground while running input on the IB-F3.
scottyt84
Member - Posts: 8
Posted: January 21, 2012 at 1:36 PM / IP Logged
I've got the manuals here in front of me and I don't see it, what wire color is it by chance?
jstruckman
Copper - Posts: 465
Posted: January 21, 2012 at 2:21 PM / IP Logged
well after looking at the manual either, I dont see a ground when running wire either(which I find strange). You could use the ignition ouptut on the satelllite relay remote port and use a relay to make it a negative signal. this will give a  negative output while the remote start is running.
scottyt84
Member - Posts: 8
Posted: January 21, 2012 at 2:31 PM / IP Logged
Look at page 29, a=the diagram at the very bottom, looks like I could use the negative igition or negative start off the red port or the negative ignition on the blue port couldn't I?
jstruckman
Copper - Posts: 465
Posted: January 21, 2012 at 3:05 PM / IP Logged
You would want to use a neg. ignition, not starter. Starter only engaged during crank. the bypass has to see a negative trigger before the remote start attempts to crank. i just looked at the wire diagram, I didnt actually look through the whole manual. So if there is a neg. output ignition then you could use this and not need a relay.
scottyt84
Member - Posts: 8
Posted: January 21, 2012 at 3:21 PM / IP Logged
I will give that a try, if not I got about 100 relays laying around, I will go that route instead. Thanks for the help!
mustyk@att.net
Copper - Posts: 132
Posted: January 24, 2012 at 10:34 PM / IP Logged
Red Satellite relay port blue wire
thetopinstaller
scottyt84
Member - Posts: 8
Posted: January 25, 2012 at 4:19 PM / IP Logged
thank you sir
mustyk@att.net
Copper - Posts: 132
Posted: January 25, 2012 at 10:07 PM / IP Logged
No Prob
thetopinstaller
