2000 toyota avalon python 1401
kog506
Member - Posts: 29
Posted: February 15, 2012 at 10:18 PM / IP Logged
Same as Viper 5101.
1) I attempted to install it earlier, I failed. The car did not start or crank it just flashes 7 Times which mean the manual mode is active but I wire the neutral safety wire to ground. or I have to program it to Automatic mode? if yes, How do I program it?
2) the H3 harness, I used all of them. Should I be using all of them? If I don't, can someone provide me the details on what and where to connect the wires?
H3/1 PINK IGNITION 1 INPUT/OUTPUT
H3/2 RED / WHITE (+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87
H3/3 ORANGE ACCESSORY OUTPUT
H3/4 VIOLET STARTER OUTPUT
H3/5 RED (+) FUSED (30A) IGNITION 1 INPUT
H3/6 PINK/WHITE IGNITION 2 / FLEX RELAY OUTPUT 30
H3/7 PINK/BLACK FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
H3/8 RED / BLACK (+) FUSED (30A) ACCESSORY/STARTER INPUT
3) How do I program the PKALL correctly?
4) What are the minimum requires just to test the remote start? ( H3,H1, and neutral safety hooked up or more?)
pts760
Copper - Posts: 403
Posted: February 16, 2012 at 1:00 AM / IP Logged
neutral safety needs to be grounded, the toggle switch (if it has one) needs to be in the right position, and automatic transmission needs to be programmed. I believe on the new DEI junk that all the units are default as manual trans. I'm not 100 percent sure on how to program those units, its been a while, but it should be in the install manual. What is up with the12volt.com forums and DEI? I guess thats why there's always posts on these products...not user friendly and full of bugs. Sorry to rant on your post.
I drink current, eat ohms, and bleed voltage
ropuma
Copper - Posts: 102
Posted: February 17, 2012 at 11:54 AM / IP Logged
Program remote starter for automatic, Default from company is manual transmission,Check the safety switch is in the right position.
