08 grand caravan and evo chr
ziggyb222
Silver - Posts: 593
Posted: February 16, 2012 at 6:47 AM / IP Logged
Going to do my first T-Harness install on a 08 Chrysle Grand Caravan. I have the harness THAR-CHAR2 non tip start and the EVO-CHR. I usually install DEI units but was wondering what brands are compatable with the EVO-CHR data set up. I see there are different types...one way  two way and different protocols on the data, Can someone give me a little more information based on thier experience with installing this set up??? Thanks so much!!!!!!
Platinum - Posts: 7,828
Posted: February 16, 2012 at 7:07 AM / IP Logged
Not sure which brand of R/S you are using.  However here is a link to Fortin that lists all the
remote start brands and models that directly support the Fortin DataLink Protocol :
https://ifar.ca/en/datalink/
Additionally, if you have the Fortin FlashLink USB cable I believe you can flash the EVO-CHR with
the DEI DBI D2D protocol and with the correct harness connect the bypass to a R/S unit that supports
that protocol.  Just check the "D2D" box when you use the FlashLink Updater program .
I believe Tedmond' is very familiar with Fortin and that bypass.  He can provide more info.
ropuma
Copper - Posts: 102
Posted: February 17, 2012 at 11:18 AM / IP Logged
use page #5 and #10 . from installation manual (fortin elec.)It will be fine.
