2003 chrysler town country parking lights
usmcvet
Member - Posts: 10
Posted: August 05, 2012 at 1:37 PM / IP Logged
Installing a R/S on a 2003 Chrysler T & C and it says the parking light wire is a NEGATIVE BROWN / white at the switch,but there is no WHITE/ brown or BROWN / white at the back of the parking light switch. R/S works fine but having problems finding the parking light wire. Thanks !
Posted: August 05, 2012 at 3:15 PM / IP Logged
Go to the Downloads/Manuals section above, in the right hand search bar, enter DEI 1082.
It's more complicated than you think, requires a relay and a resistor.
usmcvet
Member - Posts: 10
Posted: August 05, 2012 at 3:30 PM / IP Logged
Ok,Thanks !   On the relay # 87 is to the resistor,just wire both ends of the resistor together and wire to # 87 on the relay ?  Thanks !
usmcvet
Member - Posts: 10
Posted: August 05, 2012 at 3:39 PM / IP Logged
I see now about the resistor,one ends goes to ground. On the # 30 on the relay it says it goes to lights. What lights ?
Platinum - Posts: 7,827
Posted: August 05, 2012 at 4:07 PM / IP Logged
At the light switch connector there is a WHITE/ Brown wire ( MUX wire ).  You cut that wire and connect the correct ends to the relay pins shown.  You are isolating the switch when the R/S outputs its' Parking Light signal and applying the 2.1 k ohm resistor to the vehicles MUX circuit to turn on the Parking Lights.
enice
Silver - Posts: 857
Posted: August 06, 2012 at 10:41 AM / IP Logged
Just get a WHITE/ orange(+) wire at the driver's kick panel. No need for a relay or resistor.
Posted: August 06, 2012 at 10:46 AM / IP Logged
Ta Eric, I've only ever done Audio, Bluetooth and tracking, heck it's called a Chrysler Voyager here and built in Austria!
Sunday, November 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
