2007 Nissan Murano door trigger wire
minhbach
Copper - Posts: 93
Posted: August 28, 2012 at 6:31 PM / IP Logged
  I have a hard time to find the door trigger wire for Nissan Murano 2007. Wiring diagram said it is Red(-) above the gas pedal at BCM. But I still can't find the right one. If I can get a bit more info like the pin location and gauge of this wire. If that is not the right wire. Please help me with the right wire. Thanks a bunch
flobee4
Silver - Posts: 585
Posted: August 28, 2012 at 6:55 PM / IP Logged
Its in the black 15 pin plug, pin 8. Its looks like its the only solid red wire at the black plug. The other red that's in that plug has a strip.
minhbach
Copper - Posts: 93
Posted: August 28, 2012 at 8:58 PM / IP Logged
So Flobee4, this is the 15 pin plug at the bcm correct above the gas pedal. Do you know gauge size for this wire. I will try this out and let you know. thanks for your info.
soundnsecurity
Gold - Posts: 2,720
Posted: August 28, 2012 at 9:29 PM / IP Logged
door trigger wires on nissans are somewhere between 22 and 18 gauge
