01 gmc yukon xl
thebeast123
Posted: November 07, 2012 at 7:41 PM / IP Logged
Need remote start and alarm wiring
Platinum - Posts: 7,827
Posted: November 07, 2012 at 7:43 PM / IP Logged
offroadzj
Gold - Posts: 2,043
Posted: November 07, 2012 at 7:44 PM / IP Logged
12volts      red (40A)      +      ignition harness
Starter      yellow      +      ignition harness
Second Starter      N/A
Ignition      pink      +      ignition harness
Second Ignition      white      +      ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition      N/A
Accessory      orange      +      ignition harness
Second Accessory      brown      +      ignition harness
Keysense      lt. green      -      ignition key switch
Power Lock      lt. blue      +      BCM, brown plug, pin A4
Notes: The BCM (Body Control Module) is under the driver dash.
Power Unlock      white      +      BCM, brown plug, pin A3
Notes: The BCM (Body Control Module) is under the driver dash. On some models, to unlock the driver door only, use lt. green (-) at the BCM, lt. blue plug, pin A4.
Lock Motor      gray      5 wire      driver kick, door harness
Unlock Motor      tan      5 wire      driver kick, door harness
Parking Lights+      brown      +      BCM, lt. blue plug, pin B6
Parking Lights-      white      -      BCM, lt. blue plug, pin A5
Hazards      same as turn signals
Turn Signal(L)      lt. blue      +      turn signal switch
Turn Signal(R)      dk. blue      +      turn signal switch
Reverse Light      lt. green      +      inside rear view mirror
Door Trigger      tan      -      BCM, purple plug, pin B4
Dome Supervision      gray/black (dome lamp), dk. green (puddle lamp)      -      BCM, lt. blue plug, pins A3 and A8
Trunk/Hatch Pin      pink/black      -      BCM, lt. blue plug, pin B10
Hood Pin      N/A
Trunk/Hatch Release      locks/unlocks along with doors
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      lt. green (driver door key cylinder)      -      BCM, purple plug, pin B3
Disarm No Unlock      see factory alarm disarm
Tachometer      white      ac      ECM, plug labeled red, pin 10
Notes: The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover.
Wait to start      N/A
Brake Wire      white      +      brake switch or steering column
Parking Brake      lt. blue      -      parking brake switch
Horn Trigger      black      -      BCM, brown plug, pin A9
Memory Seat 1      white      +      memory module under driver seat
Memory Seat 2      purple      +      memory module under driver seat
Memory Seat 3      N/A      +
Interface Module:     Category:
Immobilizer Bypass     Required:
Yes     Type:
Passlock II
Part #: GMBP
Alternate Part1 #: PLJX
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes:
Combo Interface     Required:
No     Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year. Key sense input of the 1700G is not needed when using it on GM Trucks
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
